| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Failed SMOG Check. HELP
__________________
'07 Tacoma Double Cab V6 4WD Last edited by Bassinfool; 09-27-2006 at 01:25 PM. |
#2 (permalink) |
I think mine idles at 900-950 with AC on? Is 800 what the state says it has to idle at?
Sorry I can't help good luck.
__________________
Kevin '95 4Runner SR5 4x4 3.0 Last edited by kmcc78240; 09-27-2006 at 01:47 PM. |
#3 (permalink) |
I think your SMOG guy is blowing smoke the last I heard it couldn't idle above 1100 RPM. I have my idle set at 1000 and I have never had a problem, even at a Test Only. Lover the idle and take it back for a free re-test.
#4 (permalink) |
That's my question, what is the best way to lower the idle? AFM screw? Thanks, again!
__________________
'07 Tacoma Double Cab V6 4WD |
#5 (permalink) |
There is a screw on the throttle body facing the front of the vehicle which will adjust idle speed.
#6 (permalink) |
Set the TPS correctly: http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment
Then set the base timing (w/ test jumper installed) and set the idle speed to the proper value (using the large air bypass screw on the throttle body).
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#7 (permalink) | |
Quote:
As a previous guy said, lower the the idle with the TB screw adjust, clockwise if I recall correctly.
__________________
Richard "Science by consensus... is not Science." Richard Harper -1988 '94 Toyota 4Runner V6 3L 158K miles 14mpg '85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg '08 Honda Ridgeline RT 2.6K miles 16mpg '06 Honda Rincon ATV 410miles/65hrs 22 mpg |
#8 (permalink) |
Just got mine checked. I don't know about you guys, but in Idaho the idle speed is set at 775 rpm +/- 425.
__________________
'83 Toyota 4x4 '79 Chevy Luv '68 VW Baja Bug |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Failed Smog Check | igogusto | 95.5-2004 Tacomas & 96-2002 4Runners | 51 | 02-05-2009 04:53 PM |
| Failed Emissions/Smog! | NaeSLaS | 86-95 Trucks & 4Runners | 18 | 02-04-2008 06:36 PM |
| Another failed smog thread | 87_Runner | 86-95 Trucks & 4Runners | 2 | 06-13-2007 11:12 AM |
| Smog Test Failed - Need Help | junbug | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-15-2005 09:49 AM |
| Help with failed smog test. | desertoy | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-17-2002 02:40 PM |
