Extreme vibration at low speed acceleration
Old 12-04-2015, 08:06 AM
Thirstypeanut's Avatar
Howdy all Yotaers out there, my truck has recently picked up an odd habbit. When accelerating from a stop the whole truck (mostly the front end I think, though) vibrates violently until I reach about 15 mph or let off the gas, then It runs smooth at all engine revs and speeds. engine mounts are fine, I just rotated my tires, Ball joints are recently replaced.
It is an 86' pickup rwd and 22re.
any help you guys can provide will be much appreciated
Old 12-04-2015, 08:16 AM
offroadnutz's Avatar
Do a search here on "death wobble"
This may be your problem. At least a place to start looking.
Old 12-04-2015, 09:46 AM
blake.nemitz's Avatar
did you have the driveshaft off? out of phase ujoints can feel like that
Old 12-04-2015, 08:58 PM
I'm thinking U-joints myself, and probably going to replace the center bearing and bushing.
Old 12-06-2015, 06:34 AM
I've done quite a bit of research out there and everyone who had driveline problems didn't have the bad vibrations until at least 40 mph, is this something that could really present a problem at 10 to 15 mph? I guess I'm just having trouble understanding why this problem presents itself at low speeds and not at any higher speeds.
Old 12-08-2015, 09:38 AM
Innocent Fool's Avatar
If it's a 5 spd push in the clutch when it acts up and start coasting. If it goes away you might want to look at your clutch.
Old 12-09-2015, 07:47 AM
It is an auto 4 speed with O/D (which doesn't work, but that is for another thread)
Old 12-11-2015, 04:22 PM
So looks like there are 3 u joints under there, any thoughts on how to tell which one is bad? none of them feel loose.
4x4YOTA
08-23-2016 09:08 AM
83
11
10-19-2015 04:57 AM
Yota12
10-10-2015 05:24 PM
BIGDEERHUNTER
10-06-2015 03:09 PM
crash813
09-27-2015 07:15 AM
Quick Reply: Extreme vibration at low speed acceleration
