extending dif breathers quick question
Old 04-02-2009, 12:37 AM
Cwaters1184's Avatar
i was reading 4crawler's writeup on the subject (http://www.4crawler.com/4x4/CheapTri...html#Breathers) just want to make sure the 1/8" NPT fitting works with the front IFS diff as well?
Old 04-02-2009, 02:06 AM
razrwild's Avatar
easiest way to tell is to pull the fitting that's in your diff already and match it up at the hardware store or find a FSM and see if its listed
Old 04-02-2009, 02:59 AM
GSGALLANT's Avatar
The front diff breather is not already extended up into the engine compartment in an 1987 4Runner? I know my 2002 came extended from the factory. I'm not sure if my '93 was or not... I can't remember, and I don't own it anymore.
Old 04-02-2009, 07:41 AM
yeah the newer tacoma's and runners had factory installed extended IFS breathers but not on the pre 95's i believe
Old 04-02-2009, 07:45 AM
nv4runner's Avatar
1/8" NPT will work. For the front I used a 18" NPT 90* elbow and a 1/8" NPT male threaded hose barb to relocate my breather. In the rear I used just the threaded hose barb and some hose of course.
Old 04-02-2009, 08:20 AM
great thanks. any reason why you used a 90 degree elbow?
Old 04-02-2009, 08:22 AM
raydouble's Avatar
Front and rear diff breather threads on my 1990 pickup were M10 x 1.0
Old 04-02-2009, 08:33 AM
GSGALLANT's Avatar
Bummer!
Old 04-02-2009, 09:02 AM
metalhed's Avatar
You should use an elbow or an angled nipple to avoid the oil pan which is very close to the hose leading off of the breather. I did not use an elbow, but added some thermal sheathing over the hose, to avoid the oil pan melting the hose.
Old 04-02-2009, 09:10 AM
Matt16's Avatar
Nissan axle breathers thread into the the Toyota axles and have a much more pronounced nipple that is really easy to attach hose to. They're about $7 ea. from Nissan. They are also easy enough to bend to clear the oil pan.
Old 04-02-2009, 09:14 AM
toyNG's Avatar
somewhat of a hi-jack...
When using the elbow, do you have to worry about the gear oil getting stuck, thereby causing a functional plug or obsruction? Since gear oil is pretty thick, I'm wondering if it won't be able to flow through the flat portions created by the elbow.
Old 04-02-2009, 10:20 AM
raydouble's Avatar
The level should never get that high in the diff, if it does it's overfilled.
Old 04-14-2009, 02:48 AM
StangBanger's Avatar
Very usefull..
Old 04-14-2009, 01:48 PM
iamsuperbleeder's Avatar
or you roll the truck over, but then you've got other issues
Old 08-12-2009, 11:57 PM
hellfire's Avatar
I pulled the silver caps off the breathers with pliers, then I got some 12mm see through hose and plugged it on with some really tight hose clamps, it works so good.. I've done alot of flexing and wheeling since I installed them and no water in diffs or hoses haven't popped off...
Cost less than $10 man..
Old 08-13-2009, 11:42 AM
orbital02's Avatar
Talking
$10 is way cheaper than flushing two diffs...
jashoeuh
11-26-2017 07:01 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
thefishguy77
08-09-2015 04:15 PM
ksmudrunner99
07-21-2015 05:33 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: extending dif breathers quick question
