Exhaust System Issue...
I have an 88 toyota 4 x4 pickup truck. It has a22RE fue enjected it is a 5 speed I recently swaped out my exhaust manifold from stock to a 2 1/4 inch header. Since then we have added the 2 1/4 inch pipe cherry bomb muffler what I need to know is can I use the stock converter for the set up? If not what do I need parts wise? And where can I purchase the parts (if any)?
yes, you can use the stock converter.
you'd need to adapt the flanges on the converter to flanges on your tubing, or cut the flanges off and weld it it.
You can also use an aftermarket converter if so desired.
you need to put the O2 sensor as close to the original location as possible.
some are, some aren't.
http://store.summitracing.com/egnsea...663&D=%2D99663
39 Thieves
01-06-2017 01:08 PM
defrag4
07-31-2015 10:50 AM
