engine/tranny dropped in together?
Old Jun 30, 2008 | 08:25 AM
ddwyer's Avatar
I am changing the engine in my 94 22R with MT. It was a major PITA to decouple the tranny from the engine before I pulled the engine. The shop manual says that they can be pulled, and re-installed together, but I didn't think that I could it with my limited hoist height, so took them apart for removal.
Because I fear major hassles trying to align the MT and the engine after engine installation, I am considering bolting them together outside the truck and dropping them in as one unit. I figured it might be worth dealing with the extra headaches to preclude the under-vehicle jockeying of the MT. For example, I was considering taking of the wheels to get the nose of the truck lower to give me the extra working height.
Is it reasonable to think that I can install the engine/MT as a single unit? If so, are there tips on doing it?
Old Jun 30, 2008 | 08:44 AM
dirtoyboy's Avatar
If you already have them seperated just put them in that way.....
Stabbing the tranny isnt that hard if you have the correct tools.....Ive done it by myself a few times.....
The only bolts that are somewhat difficult to get in are the top 2 bellhousing bolts....a couple long extensions make short work of it though
Old Jun 30, 2008 | 09:24 AM
netgodsrdn2's Avatar
The top two bolts are actually quite easy with a long extension and the back of the transmission/transfercase lowered a bit on a jack.
Old Jun 30, 2008 | 09:37 AM
Kaydon's Avatar
I dropped my engine and trans back in bolted together.
Although mine is 2wd.
Old Oct 22, 2008 | 03:07 PM
Flek23's Avatar
Thumbs up brilliant
Thanks a billion. 3 feet of extention and a swivel and bam bolts are out. Add laptop station to must have tools. I didn't even have to lower the tranny
RDubya
Feb 10, 2017 04:46 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
shredder4286
Oct 1, 2015 01:09 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
