Engine swap/check engine light? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-29-2006, 06:30 PM   #1 (permalink)
I'm recently replace the engine in a 93 p-u with a used engine (100,000mile).
My check engine light is on, so I did some research and did the jumper wire in the diagnostic box and got a two digit number, 21. Which has to do with the O2 sensor.
I'm not sure if the light was on previous to replacing the engine, since I did not own or run it.
I have been checking my gas milage and I'm getting 17mpg (city/highway), which doesn't seem to be off the norm from what I read. I would like to get more MPG if possible. I have a highway trip coming up and plan on checking highway mpg.
Should I have a shop do a diagnostic check to make sure I need a O2 sensor before I go replace it. If I do replace it, will the check engine light go off if that was the problem or will the shop need to clear it off?
Thanks
spacoli is offline
Old 11-29-2006, 07:39 PM   #2 (permalink)
Send a message via AIM to dcg9381
There isn't a real diagnostic check that I know about for an 02 sensor, unless it's totally dead...
I'd replace it yourself, it should clear the code.
__________________
http://www.22REturbo.net
dcg9381 is offline
Tags
check, engine, light, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
check engine light? myfinalcoffin 86-95 Trucks & 4Runners 3 02-20-2006 08:04 AM
Check Engine Light!!! MUDN4R 86-95 Trucks & 4Runners 2 02-08-2006 07:23 PM
Engine Miss/Check engine light - Possibly TPS? Extremesolo 95.5-2004 Tacomas & 96-2002 4Runners 2 09-17-2005 09:58 PM
Check engine light is on. What to do now? cccp 95.5-2004 Tacomas & 96-2002 4Runners 22 03-30-2005 05:50 PM
check engine light + engine miss descendents 95.5-2004 Tacomas & 96-2002 4Runners 6 11-03-2003 07:51 PM
2009 InternetBrands, Inc.
