Engine swap
Old Mar 18, 2006 | 08:23 AM
scott7689's Avatar
Engine swap
I am about halfway through a motor swap into my '91 pickup. It originally had the 3.0 6 cyl but i am putting a 22RE out of a yota i totaled about 4 weeks ago. I was wondering if it was possible to get out of swapping the wiring harness for the interior of the truck. I am not sure if it will plug into my computer or not. Some help w/ this would be greatly appreciated before i go to tearing the dash out of this truck. Thanks
Old Mar 19, 2006 | 03:05 PM
Radyota's Avatar
You are aware that the motor mounts on the frame have to be moved (welded), right?
Old Mar 19, 2006 | 03:10 PM
Elton's Avatar
and are you aware the tranny from the v6 wont work with the 22re
Old Mar 20, 2006 | 06:23 AM
scott7689's Avatar
i have already welded new motor mounts and i am using the transmission and driveshaftes from the 22RE. I was told that i would have to swap out all of the interior wiring harness and gauges out of the 6 cyl truck and put the 22RE harness in it. I am trying to figure out if there is any way around this before i tear the dash apart. I would have never taken on this project if i had known it would be this much trouble. i would have just dropped a 4.3 in it.
Old Mar 20, 2006 | 06:27 AM
NCSU-4runner's Avatar
if you get the wiring diagrams for both you can make you're own harness, thats what i did w/ my 7MGTE. Takes a solid afternoon but its worth it. If you are looking for the bare minimum theres only about 6 wires you HAVE to use.
Old Feb 13, 2007 | 05:11 PM
YodaKrawler's Avatar
hey i was wondering if that worked for you if it did do you think that you can help me do this. i am turning my 22r to a 22re and putting it in my 91 krawler cause the engine seized and the 22r that i have is in great shape and i have sent it through everything and it is still going. 240000 on it it has out lasted that v6.
Old Dec 18, 2007 | 09:05 AM
h2racing's Avatar
Is the 5 speed from the v6 the same as the one from the 22re? And if it is are the bell housings interchangeable? Is the v6 bell housing any larger than the one used on the 22re? I have a 91 pickup and am putting an isuzu diesel in it but I need a larger bell housing. any help would be appreciated.
Old Dec 18, 2007 | 11:27 AM
4rnr's Avatar
They are different
The v6 has the r150f behind it
The 22re has the w56 behind it
Old Dec 18, 2007 | 11:36 AM
Flash319's Avatar
I thought the engine wiring harness was somewhat separte from the interior? I would think it would not be that bad of a job. I will be doing it in the spring as well as I have a nice 95 body that had a V6 Auto in it going onto my 89 frame with the 22re 5speed.
Old Dec 18, 2007 | 04:42 PM
InternetRoadkill's Avatar
The engine harness is mostly separate from the interior harness. There are some wires which go to the instrument cluster and possibly the O2 sensor which run under the dash. I think these are on a separate plug to the ECU. If you have a cruise control and/or auto tranny, then there's definitely wires running under the dash.
The yota harnesses are a nightmare to sort out. Toyota made dozens of variations even within the same model year. I made a harness for mine from 3 different harnesses to get one that fit.
Old Dec 18, 2007 | 04:50 PM
fillsrunner4's Avatar
Ide just sell the 22re and go for a 4.3. You could get a whole donor vehicle for under 1500 easy. Youll need to do some wiring to do the 4.3 or 22re swap. I suggest if your going to use the 22re then go to tech info to get the schematics. The yota harness is easy to work on and make work. if you dont like wiring... good luck
Old Dec 22, 2007 | 06:37 PM
Dr Tweak's Avatar
If you really want to complete that swap and you don't want to pull the dash harness, shoot me an email, I can probably make you a plug and play harness with what you have.
drtweak@phoenixtuning.com
-Doc
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
