Engine swap 22re 2WD to 4WD??
Old 06-29-2013, 01:22 PM
SIDEWAYS692's Avatar
Im thinking about taking out my 2WD engine(89 pickup 22re) and put into a (91 4runner 22re 4WD) will everything hook up drive train? Trannys?
Old 06-29-2013, 02:12 PM
YotaWoRx's Avatar
The engine will mate up to the 4wd tranny no prob
Old 06-29-2013, 02:16 PM
Sweet man I appreciate it! I have new 31x10.5 u think it will be a huge difference power and gas the extra weight?
Old 06-29-2013, 02:27 PM
YotaWoRx's Avatar
Why are u swapping the engine? The one in the pickup and the one in the 4 runner are the exact Same motor. (Maybe some slight emissions changes but no biggie) didn't u drive the 4runner with the 22re?
Old 06-29-2013, 02:43 PM
milkybar's Avatar
Engine swap no issues but the clutch plate is smaller.
I did this and after three years had to put in another new clutch. Regular driving ok, but if you 4wheel you will be replacing the clutch more often.
Old 06-29-2013, 02:48 PM
No bought the 4runner cheap blown headgasket 2weeks ago good interior and everything and the truck is all beat up but i put a rebuilt engine in 1 yr ago
Old 06-29-2013, 04:03 PM
YotaWoRx's Avatar
Like milkybar said, get a new clutch and replace rear seal since the motor will be out. Or why don't u just do the gasket?
Old 06-29-2013, 04:52 PM
Causr im not sure thats all it is could be more in the head damage if its just the headgasket it will go in my truck to sell
Old 06-29-2013, 05:12 PM
Toyota~Boy's Avatar
You will have to change the following parts in order to stick a 2wd engine into a 4wd truck.
Oil pan
Oil pickup tube
Flywheel
Clutch kit
Now that you have that info here's some more you need to know.
The two engines are the same however there from different years. Your 89 engine may or may not have different plugins on it. For example the injects may have oval plugins on the 89 but have square on the 4Runner. If your going to swap engines I'd highly suggest that you use the Entire EFI setup from which ever vehicle your swapping the engine into. That way you know that everything will hook up correctly. It's easier to swap intakes and such while the engine is out rather then doing it while its installed.
Just my 2 Cents good luck
Old 06-29-2013, 11:18 PM
I'm taking everything but tranny out of the 89truck and use the 91 4runner I put new shocks and up control arms with a fab tech lift, also torsion bars all of this can go on? Truck has 5 lug and 4runner has 6lug still interchangeable?? I got wheels figured out already, early Tom is start of it. Brand new Ingersollrand guns
Old 07-08-2013, 09:38 AM
Hey guys I have everything off and ready to pull the engine only, leaving the transmission in the 4runner what do you need to do to separate them?? its a manual 5speed with rear dru vling off and 2 too tranny bell housing bolts left holding it together.
Please help looking to pull within hrs
Old 07-08-2013, 09:57 AM
derockus's Avatar
If you're asking how to pull the last 2 tranny bell housing bolts you gotta go thru the shift lever cutout in the cab with about 30" of extensions. Helps to have someone in the wheelwell guiding the socket onto the bolt.
Separating them is just a matter of wiggling and pulling. Be sure to support the tranny because it will be under a bunch of strain if left hanging with no engine.
Old 07-08-2013, 11:30 AM
Your a life saver man thank you I almost broke some tools yesterday haha I wilk give her a try and everything is supported jack on the tranny and cherry pick on the engine
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
noahstancik
07-10-2015 11:18 AM
hhsanfor
06-30-2015 06:08 PM
Alex Bessinger
06-28-2015 10:05 AM
Krash
07-30-2002 02:16 PM
Quick Reply: Engine swap 22re 2WD to 4WD??
