ENGINE overheating 3.0 89
Old 05-29-2016, 12:44 PM
Trent Viccari's Avatar
I am having trouble figuring out why im overheating i changed out the thermostat but that didnt help, there is pressure in my hoses, also when too hot pressure builds up in the radiator to the overflow value. Need help !!!
Old 05-31-2016, 05:30 PM
cbr600rx7's Avatar
Can you be more specific?
Does it get hot when driving at speeds or just when sitting?
Old 05-31-2016, 05:43 PM
Tville yota's Avatar
Water pump bad. Run with thermostat out for a day or two. See what happens to temp then. Pumps turning you'll not run hot. Flush everything real good to put back straight water tell you figure out. Don't let it run hot.
Old 05-31-2016, 10:08 PM
SgtSuprman's Avatar
You could have the wrong mixture of coolant or have air pockets or a few other things, definitely need to provide a bit more info...
Old 06-01-2016, 12:20 PM
cbr600rx7's Avatar
Need to trouble shot the issue to figure out what's going on. Just guessing and throwing parts at it is a good way to waste time and money.
If you can drive it at 45-65 mph for a sustained period of time with out it over heating it's probably your fan clutch failing. Simple and easy replacement. This is assuming nothing is blocking your radiator and your fan shroud is still in place.
If it's starts getting hot randomly and will suddenly drop back down to operating rage while sitting it could be a sticking T stat.
Like others have said make sure you don't have air in the system and that you are running a 50/50 mix of coolant and water.
Old 06-05-2016, 08:07 AM
ZUK
ZUK's Avatar
Original radiator? Look in the top and is the white corrosion in the slots? Recommend a new radiator from someplace like https://www.radiator.com/
Old 06-06-2016, 05:06 PM
This site is saying I said something I didn't say. UH I m confused. It let me edit and the post above. Was me. Not cool. At all.
Last edited by Tville yota; 06-23-2016 at 06:30 PM. Reason: Not my freaking post. How could this happen???
87tyota77
04-22-2020 07:00 AM
SgtSuprman
05-31-2016 09:43 PM
BlakeNance1
05-30-2016 10:13 PM
deevemon
05-28-2016 12:54 AM
DaddyRisley
05-27-2016 11:01 PM
Quick Reply: ENGINE overheating 3.0 89
