Engine keeps stalling
Old 02-01-2007, 06:23 PM
MudHippy's Avatar
Oh yeah, I'll be here ALL night. I'm usually not this cocky, but try seein' it from my perspective.
Old 02-01-2007, 06:46 PM
Lifelongtoy's Avatar
Ok MudHippy, Saturday has been reserved for fixing my truck only. I'v got a couple people out there with me so we should find something. And Ill be damned if Im not checking that damn EGR first thing. So I should have a good update Saturday evening, if I don't solve it tomorrow.
Until then, my ohm reading for the AFM was off. What might that mean?
Old 02-01-2007, 07:00 PM
MudHippy's Avatar
May the force be with you...always. AFM hmmm... let's see...
Old 02-01-2007, 07:03 PM
4runnerx3's Avatar
The THA is the air temp sensor which is inside the air flow meter. Air temp is also used for air fuel ratio.
Old 02-01-2007, 07:09 PM
  #25
All seem to be within specs except for E2-Vb. Im getting a funny reading where it will flash some random number below 200 Ohms then drop to zero.
Old 02-01-2007, 08:22 PM
  #26
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Originally Posted by MudHippy
EGR, how else, any challengers if he ain't got with the temp sensor? I am truly dying to recieve some well earned confirmation. Or, learn from a master. I will admit defeat graciously.
I'll tell you what. If it is the EGR, I will admit no defeat. But, I will admit I was wrong. But, how is the air/fuel mixture going to be correct if the ECU is not getting a correct reading on the temp of the engine? Listen, my motor was doing the same damn thing when the ECT went bad. I bypassed the EGR thinking that was the problem. It didn't fix it! It would take him far less time to just check the ECT first than to do the EGR thingy. But, hey...you guys do what you want. I'm outta here! TA!
Old 02-02-2007, 06:04 AM
  #27
Don't worry, Ill try the temp sensor also. You guys are a great help.
Now, does anybody know the symptoms of a faulty AFM, specificaly between E2-Vb?
Old 02-02-2007, 12:31 PM
  #28
4runnerx3's Avatar
I would check the resistance on E2 by moving the flap opened all the way and closed.
Old 02-02-2007, 02:59 PM
  #29
MudHippy's Avatar
You da man, thook!! All due respect here, nothin' but. I'll go ahead and admit that loss, regardless. Because, I'd be lyin' ta say ya didn't just school me.
Old 02-02-2007, 03:46 PM
  #30
Can't see how I failed to mention this, but I am getting strong gas fumes from exaust and appear to be running rich.
Tomorrow will be a fun day! Im not stopping till it's fixed.
Old 02-02-2007, 04:03 PM
  #31
thook's Avatar
I'm just too curious...
Lifelongtoy, I did ask you that before. Glad you noticed it, though. That helps to troubleshoot alot.
Mudhippy, no gratuitous gestures just yet! We're still waiting to see what he finds, aren't we? I could be eating crow after all is said and done! And I may be out of ketchup....(shakes the bottle)!
BTW, did you check that sensor yet?
Old 02-02-2007, 04:47 PM
  #32
Tomorrow the sensor gets checked, everything gets checked, EVERYTHING! Absolutely everything I and my mechanic friend can think of, as well as the aformentioned beer drinkers who occasionally scoot in close enough to wiggle a wire or something with that curious look on their face.
Oh yeah, ANYBODY know what a faulty reading on that AFM would mean, E2-Vb is bad? (see diagram above)
Old 02-02-2007, 04:52 PM
  #33
thook's Avatar
Hmmm....you asked about the symptoms of a bad one. Have you checked out 4crawler's webpage? As I recall, he has a section on the AFM.
Old 02-03-2007, 03:02 PM
  #34
peacedog's Avatar
Where in Forth Worth are you lacated? I am having some of the same problems and it would be great if I can watch/help/drink beer as you try to fix your truck. In doing so maybe I can learn enough to fix mine. I am on the Westside by Carswell.
Old 02-03-2007, 04:50 PM
  #35
So after 8 hours of a tinkering' and a guessin' and one bloody finger, I figured it out......drumroll.......ELECTRICAL CONNECTION TO #1 INJECTOR AND A MINOR VACUUM LEAK. So there it is , my mystery solved. The splice from the resister to the injector was broke which caused it not to inject anything, which caused the cylinder to be dead, which caused the bad acceleration. That, coupled with the minor vacuum leak was enough to make it die at idle. Case closed.
Old 02-03-2007, 05:37 PM
  #36
MudHippy's Avatar
I called the vac leak, but forgot to mention it would do basically same thing as bad EGR. Gotta admire the stick-to-itiveness, well played! Thanks for lettin' me rack my brain for ya. Seriously, I eat, sleep, an' breathe TOYOTA, pleasure's all mine.
Old 02-03-2007, 06:12 PM
  #37
One day I shall call on you again MudHippy. Untill then, Ta.
Old 02-03-2007, 11:14 PM
  #38
thook's Avatar
Mmmmm....crow! Bar-B-Q'd...southern style! Congrats Lifelongtoy! Learning never stops...does it? (I am saying that more for me, though )
Old 02-03-2007, 11:32 PM
  #39
neilan's Avatar
hmm wish i would have sen you thred earlier coudl have told you that it was injector related from day one. Hesitation is most always caused by some major fuel/ ari problem. my injectors were partialy pluged and they would run lean then the comp would try to compensate and dump to much and it owuldnt idel or accelerate it was almost liek how it wants to die when you get low on gas right?
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
Sleaker
08-26-2020 06:03 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Engine keeps stalling
