engine hesitates...
Old Jul 3, 2008 | 01:29 PM
terrybo3's Avatar
engine hesitates...
Ok...so, when I get up in the morning and start off to work, I have to slow down to go through a dip in the street. I downshift to 2nd gear, let out the clutch after the dip, and the something seems to hesitate and the truck bounces like if I didn't know how to drive a clutch. What the heck is that???
It doesn't do it when it's warmed up.
Edit: It has had a tune up with new plugs, wires, distributor...I replaced the water pump and timing belt, and the dealer fixed the headgasket issue.
Old Jul 3, 2008 | 04:12 PM
just a 22re's Avatar
how low is your fuel maybe that dip is making it so it gets a lil more air then fuel?
Old Jul 5, 2008 | 08:04 AM
terrybo3's Avatar
It happens when the fuel tank is full and when it's empty. It did it worse before I took it into the dealer to have the headgasket issue fixed. They also replaced the #5 bearing (on the crankshaft?).
Could there be something wrong in the clutch/transmission area? The slave cylinder and master cylinder were replaced a year ago, and ever since then the clutch pedal doesn't come up all the way 100% of the time.
If the bearings are worn out on the crankshaft, would that have something to do with it? Or, would it be more likely a fuel problem?
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
