Electrical problems. Long pause before starter turns over?
Old Nov 8, 2007 | 03:26 PM
Adawg_08's Avatar
Well I have and 88 4runner 5speed 22re. Just rebuilt the motor. Sometimes there is a second pause before the starter will turn over. Sometimes it won't even turn over. If I jump it it turns over for a while before it will finally start. I have no idea what this could be.
please help me out
Old Nov 8, 2007 | 03:43 PM
ozziesironmanoffroad's Avatar
mine does about the same thing. it clicks, then you hear something whining, then it will start. i checked the OHMs, fine. checked the charging system. fine. the starter is pulling the right voltage every time. i think its the connectors inside the starter.
Old Nov 8, 2007 | 04:11 PM
Adawg_08's Avatar
yeah but sometimes mine doesn't start no matter how long you hold it there.
Old Nov 8, 2007 | 05:23 PM
MAXIMUS1968's Avatar
I am havin the same problem
Old Nov 9, 2007 | 10:59 AM
Adawg_08's Avatar
It started as just the clutch start cancel button. But now it does it every once and awhile. The clutch Start Cancel button makes it do that now. I don't touch the button but it does it if I don't touch that button sometimes too.
Old Nov 9, 2007 | 11:17 AM
that button has been disconnected for a couple years now. i dont know how to hook it back up. i didnt find any use for it anyway. lol. did it have a real purpose? or was it one of those things like the buzzer when you opened the door with the key in the ignition.. i chose to leave that disconnected
Old Nov 9, 2007 | 07:49 PM
Adawg_08's Avatar
it did it to me tonight. I played with the lights and stuff and it turned over? weird, don't know what it is.
Old Nov 9, 2007 | 08:07 PM
Spence1016's Avatar
put new starter contacts in the starter, they wear down unevenly and will cause it to not turn over sometimes
Old Nov 9, 2007 | 08:15 PM
rowdy235's Avatar
Exactly. My truck went from cranking slow to a pause to just clicking in two days and after new contacts she cranks over like new
Old Nov 9, 2007 | 08:50 PM
CyMoN's Avatar
from what I have gathered the clutch cancel is for when you are on a steep incline and you don't want to roll back this way you can keep one foot on the gas and one on the brake hit the key and the gas start going as you let off the brake no roll back.
as for you starter take it out and take it to auto zone and have it tested and check your starter relay on the fire wall the FSM has a test for it
Old Nov 9, 2007 | 08:53 PM
rowdy235's Avatar
The Clutch cancel switch is used for when you don't want to press the clutch for the engine to crank, whether this is in gear on a hill, as you mentioned, simply in neutral, or I have heard of putting it in first and 4lo and taking off slowly out of a mud pit.
Sleaker
Aug 26, 2020 06:03 AM
coryc85
Sep 9, 2015 06:24 AM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
colinmil
Jul 6, 2015 04:03 PM
