EGR what does this control, I have Code 71
Old May 7, 2008 | 01:53 PM
simpsons721's Avatar
Red face EGR what does this control, I have Code 71
I have code 71 egr
what does the egr control?
if i fix this what will my car do better?
my car currently reads as low oil pressure when running after 5 minutes and feels it runs hot but gauge reads normal
please help
Old May 7, 2008 | 03:09 PM
ozziesironmanoffroad's Avatar
71 is egr. its clogged. if you are in a SMOG area, you wont pass because you will be putting out too much NOx. i cleaned my egr out,l but i dont have the equipment to test it, i only have one more free smog test.
Old May 7, 2008 | 05:33 PM
js9924's Avatar
First of all you should search because there are a thousand threads about this topic try "code 71". anyway...
It is most likely just the EGR temp sensor you can fool the ECU by putting a 10k resistor in the connector across the terminals. I would also recommend cleaning the EGR valve and the filter in the EGR vacuum modulator.
Click on the link in my sig and you can see my egr removal write-up. In there you will see a pic of the resistor installed.
Old May 7, 2008 | 07:54 PM
943kgt's Avatar
I had a code 71 when i first bought my truck, ended up just being a vacuum line blown off my egr modulator, just take a look at your vacuum routing diagram under your hood and make sure your lines are routed correctly. Then go from there.
Old May 7, 2008 | 08:13 PM
Alex 400's Avatar
how do you clean the egr valve? I have a similar problem
Old May 7, 2008 | 08:15 PM
take it out and spray it with carb cleaner
Old May 7, 2008 | 08:21 PM
Alex 400's Avatar
hell, i can do that! Thanks. I figured it would be something like that. i will do that this weekend when i actually have sometime haha
Old May 7, 2008 | 08:27 PM
and test the vacuum
Old May 7, 2008 | 08:45 PM
Alex 400's Avatar
and test the vacuum
you mean to see if the egr is recieving vacuum or if the egr reacts to vacuum. I ahve tested the EGR to see if would open with a vacuum pump and the motor stumbled pretty hard until i released the vacuum.
Old May 7, 2008 | 09:03 PM
did u check the EGR filter?
Old May 7, 2008 | 09:14 PM
Alex 400's Avatar
i am sorry, i don't know what that is nor have i have ever heard of such a thing? where is it?
Old May 7, 2008 | 09:23 PM
not sure, im not the engine expert. as i said im having a problem passing smog. i know theres a EGR filter, i just dunno where it is. might want to ask deathcougar.. guys not human
Old May 7, 2008 | 09:46 PM
Alex 400's Avatar
alright will do thanks. i think i am going to try and blow it out with some carb cleaner and compressed air. I think i will also use the vacuum pump to hold the valve open to get some of cleaner inside of it.
Old May 7, 2008 | 10:02 PM
904_runner's Avatar
The black part on the 3.0's that have the leters q, p, and r on it. Its up front near the timing belt cover, near the spark plugs! In that area, where all the vacuum lines go in.
There is a little filter in there and i belive it connects to the egr
Old May 7, 2008 | 10:24 PM
94toy4x4fever's Avatar
whats the best way to clean the filter? Just blow it out with some air?
Old May 7, 2008 | 10:28 PM
904_runner's Avatar
buy a new one. They are tiny maybe the size of an old half dollar.
Besides, if it is dirty as mine, blowing air isn't going to do anything.
Honestly, i don't think that is the problem though
Blamalam
Mar 12, 2022 07:34 AM
mussy01
Dec 13, 2016 08:20 PM
alimant100
Jan 20, 2016 05:58 PM
Colington
Aug 13, 2015 02:21 PM
montanatruck
Jul 25, 2015 03:45 AM
