EFI Fuse Blows when engaging 4 wheel drive
By lockers wyoming9 was probably referring to locking differentials and not the Automatic Disconnecting Differential (ADD) or manual hubs. Here is an example. Toyota makes an e-locker for Tacomas and some 4runners for added traction. Have you reconnected the 4WD light switch or are you still running with it disconnected and still blowing the EFI fuse?
i'll check that out, thanks!
I've seen several cases where somebody installed a stereo and just looked for the closest wire with 12 volts or ground to use in the installation. This can cause havoc in other systems. I'd look at all the stereo wiring carefully.....maybe take it all out and wire it correctly. Good luck.
#25
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
skoti89
07-06-2015 07:45 PM
Jnkml
07-06-2015 01:20 PM
