Driveline Vibration driving me crazy!!!
So my extra-cab with the 2 piece rear shaft is driving me crazy. Good and smooth until I get into 5th gear and about 85 km/h then I get a looping vibration, wooow........woooow.......wooow. Nice eh
I put a new hanger bearing in last year when the driveline was on a different truck. I have moved that drivline (both shafts and hanger bearing) to my current truck.
I checked the bolt in the hanger bearing and both yoke bolts. I have also tried changing the rear shaft with the CV joint to another one that I have. No luck. I am starting to wonder if it is the trans but I have never had this happen to a manual before if it is the trans. Anyone with this same experience?
The vibration stops when I let off the gas. Then when I give it gas it comes back. Anyone have any other troubleshooting I should try? I was thinking maybe drop the shafts and run the trans through to 5th and see if the vibration is there with no driveshaft??? HELP!!
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Are the driveshafts in phase? (I think thats what it's called). Maybe you lost a weight balance......? Take it a driveline shop and have it re-balanced.
Location: Yotatech, because Pirate is too expensive. NorCal.
I have a vibration too. I think its the rear u-joint. I'm replacing it tonight. hope it fixes it cuz its REALLY fricken annoying. Its from like 25-60mph and worst at about 47. its not a woow....woow....woow like you describe (which i though was a pretty damn good description btw). Its more of a solid shaking through the drive line. Its still there when I let off but it is worse when accelerating.
maybe you have a loose muffler bearing
X's 2 on the U-joint possibly
the "drive shaft jiggle-test" isn't always accurate; they can feel solid, but still be bad
I have replaced the rear joint and the very front one. I also changed the whole rear shaft with another one. I read on another thread that someone had a ring and pinion cause a bad vibration?? I have never heard of this before but maybe?
I am pretty sure it is not a U-joint because it is so torque sensitive. The moment I unload the drivetrain the shake is gone. Then as soon as I start, even lightly, back into it is starts the vibration again. I have also changed the tires to known good ones to eliminate that.
I think I may pull the rear shafts and go for a drive on the front end only. This will eliminate the trans. I am going to change that rear shaft one more time as I think the weight on the one I have on there is coming off. It is a heavy vibration so I don't think it is a weight related problem.
How would I check the ring and pinion?
or, pinion bearing at rear diff? but youd prbably be leaking fluid there too, cause the seal would more than likely go if the pinoin's vibrating around...
dudes! I just replaced my rear u-joint. Took three hours lol. Had to cut the old one out (probly the original). But anyways It's sooooooooo smoooooth now! (twss) Gawd I cant wait to drive to school tmrw! You dont hear me say that too often.
Well I may have to brake down and buy a single shaft. I just hate to do that if it is not going to solve my problem but I can't find anything wrong with the shafts and joints. It is a harsh vibration so you would think that it would be easy to find...............
The transfer case mount is brand new. That was the first thing I changed because it was falling apart.
Well I think it is my trans. If I go 90km/h in 5th I get the woow woow woow. If I drop it to 4th going the same speed it is gone. That to me says that it is the trans (probebly input bearing). Any thoughts??
maybe not be a bad thing though, could just be a tone the motor makes at a certain RPM; after my header and exhaust, my 22re's loud at 2500 RPMs, eveywhere else is relitively quite
but, if it feels and sounds like it's reverberating throughout the whole truck, then the trans could be the issue.
have you looked at the fluid yet for any metal shaving or anything?
hmmmm, could be motor noise too then if you drop down a gear and your RPMs change and the sound goes away...
Might want to check the drive shaft alignment. Since it was mentioned the vibrations lessen when off the gas, that could mean the pinion on the rear axle is tipping up too high under load and causing the vibration. Letting off the gas allows the pinion to drop back down and that will cause the vibrations to drop as well:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
