Downpipe/bellhousing bracket
Old 07-05-2009, 10:53 PM
shftatsix's Avatar
Recently bought my 1993 22re, replaced the downpipe, manifold, and the gaskets down to the cat. A week has passed and the gaskets under the manifold to the downpipe have blown and the nuts are backing off the studs in the manifold.
Did a little searching of the interwebs and it looks like im missing a bracket that holds the downpipe up to the bellhousing, im assuming thats the reason my gaskets blew (the undistributed weight backed the nuts off). Does anyone have a picture of the bracket? im thinking i want to fab one up.
Also if anyone thinks this wont help my situation and have some advice id love to hear it
Thanks in advance
Old 07-05-2009, 11:00 PM
toyota4x4907's Avatar
Its not mine you bought, is it?
wait can't be..mine had the bracket...
I had the same problem with the O-gaskets between the manifold and downpipe on my '93 22re as well. Never fully got it fixed. I went through 4 or 5 new pairs of those gaskets in a year. I tried wrapping them in tin foil, using muffler tape, duct tape (obviously didn't work ), using FIPG. The best results were from the tin foil wrapped gaskets. I still blew them when I revved to 5K when I almost got stuck in some snow on the side of the road. hehe. The studs were missing when I bought it and were replaced by bolts. Try using some loctite type stuff. It worked for me, but I think I used the wrong kind and it burnt off after like 2 weeks.
and its not really the weight thats backing them off, its the being heated to high temps, expanding from it, cooling, shrinking, and rattling of the engine/exhaust.
Old 07-05-2009, 11:11 PM
shftatsix's Avatar
Probably not yours haha, im down here in WA. Although the studs were replaced with bolts on the old manifold (they were all sorts of messed up and cross threaded) and the downpipe was welded together in two places and was leaking out of both welds.
Im pretty sure any type of locktite (blue or red at least) will burn off that close to the engine. I want to try to put a jam nut on the stud behind the plain jane nut or a lock washer. But i dont think that will help much if theres no bracket to distribute that weight properly.
Old 07-06-2009, 06:56 AM
Junkers88's Avatar
Had the same problem on my 89 4runner. The nuts that were on the studs were brass and would heat and cool and work loose. I tried lock washers (doesn't work once the washer gets hot), tried putting two brass nuts on each stud and jamming them together (didn't work either). I finally went to Napa and bought a new stud set to replace two of the studs that were messed up and bought three steel nuts to replace the brass ones. It hasn't started leaking in about 1000 miles, it used to leak within 10 miles with the brass ones on there.
I do have my little bracket but it's sitting on the shelf with a bunch of other parts. Try some new studs and steel nuts and I think you'll be fine.
Old 07-06-2009, 09:10 AM
shftatsix's Avatar
yea i have the brass nuts set, this is my first back off and the studs have been in there less than 100 miles. Think i can get away with just some new nuts?
I believe the nuts are M10 1.25 pitch, right?
Old 07-06-2009, 09:29 AM
NicCantDecide's Avatar
I used red loctite on the manifold studs for my turbocharged honda, I can guarantee that created more heat than the 22re ever will. I went to take the manifold off a few months afterward and the loctite still held strong.
Old 07-06-2009, 11:56 AM
Junkers88's Avatar
I think they are indeed M10 1.25 pitch. I'd say go get the new nuts and put them on.
Old 07-06-2009, 12:00 PM
shftatsix's Avatar
Ok im gonna go grab those new steel nuts and change them out and put in some new gaskets, ill check back in in a few weeks to let future searchers know the results
Old 07-06-2009, 12:16 PM
Sponsor
Tofer's Avatar
where in WA are you (guessing by the interwebs comment, i'm going to guess seattle area and you listen to 99.9 in the morning but i could be way off)
i may have that bracket laying around in my shop. i'll look for it today and let you know.
Old 07-06-2009, 12:18 PM
iamsuperbleeder's Avatar
lol, this is pretty much the reason I did away with the stock manifold for a header...
Old 07-06-2009, 12:19 PM
shftatsix's Avatar
haha yep im in the Renton/Bellevue area and listen to 99.9 all the time
Old 07-06-2009, 12:33 PM
Sponsor
Tofer's Avatar
liquor and whores!
i'll try to find that bracket today.
Old 07-06-2009, 12:35 PM
shftatsix's Avatar
Hola bitchola and liquor and whores to you too! Its all good if you cant find it, junkers88 thinks ill be find w/o it
Old 07-08-2009, 05:39 AM
Junkers88's Avatar
Did you get it fixed?
Old 07-08-2009, 05:55 AM
oldgold3vze's Avatar
X2, but if I had to do it again I would have kept the stock manifold. The Pace Setter headers I got are LOUD...
Old 07-08-2009, 02:18 PM
shftatsix's Avatar
So far so good, but last time it took a week to leak so ill let ya know if the steel nuts outlast the brass
Old 07-08-2009, 06:52 PM
Sponsor
Tofer's Avatar
i can not find the bracket afterall.
Old 07-08-2009, 07:08 PM
shftatsix's Avatar
Its all good, thanks for looking tofer
Old 07-09-2009, 12:32 PM
shftatsix's Avatar
Had some extra time today so I just popped under the truck and checked if the nuts backed off. From what I can tell they haven't moved a bit as of 80 miles.
scott90
10-04-2015 09:21 AM
voiddweller
10-02-2015 07:47 AM
ktm192k
10-01-2015 08:47 AM
Brodetski
09-30-2015 11:50 PM
tysen86
09-25-2015 11:15 PM
Quick Reply: Downpipe/bellhousing bracket
