Does this sound normal? "Video inside"
Old 05-01-2013, 03:12 PM
RobertIII's Avatar
So I have a 1994 Toyota Truck 4x4 I just got with a 22re motor in it with only 23000 miles on it. It is a manual transmission. Anyways I am new to this motor and something just sounds weird to me? Maybe its just me? Anyways here is a short clip of the engine idling. What do you all think? Any help is appreciated. Thanks
Old 05-02-2013, 12:09 AM
RSR
RSR's Avatar
Sounds like a vacuum leak to me. But I'm a 3 slow man, so can't say for sure...
Old 05-02-2013, 09:29 AM
xylicon's Avatar
Sounds just fine and dandy to me.
Old 05-02-2013, 12:59 PM
RobertIII's Avatar
I think I am just paranoid! Better to be safe then sorry I guess!
Old 05-02-2013, 02:57 PM
Hilux4Life's Avatar
I didn't hear anything out of the norm.
Looks like a nice clean engine. That header cover looks almost new.
Old 05-02-2013, 04:12 PM
RobertIII's Avatar
IT should! The motor only has 22,000 on it, better yet the frame only has 130,000! I just bought it off a guy a few weeks back! It came with all the receipts and everything for the new motor!
Old 05-02-2013, 06:38 PM
YotaWoRx's Avatar
I thought a heard a whine, like a bearing in the idler pulley is bad/dry.....
Old 05-02-2013, 07:10 PM
junk4u's Avatar
I'm kind of leaning toward yotaworx, I can hear a whine like the bearing on the pulley. I would do the following, check the chain (I know the motor has only 23,000 on it) and the pulley.
Old 05-02-2013, 07:46 PM
YotaWoRx's Avatar
my idler pulley bearing sounded exactly like that. I removed the pulled, popped the bearing out, pulled off the dust covers and cleaned/regreased it. works great.
Old 05-02-2013, 08:08 PM
RobertIII's Avatar
I will give that a try tomorrow. Sorry to be a noob, but which on is the idler pulley? What grease did you use?
Old 05-03-2013, 03:48 AM
junk4u's Avatar
Here's a pic of the front. There are 2 that could be checked. The A/C and the Idler, both have a bearing that gives issues, the Idler more so than the A/C. Hope this helps.
Old 05-03-2013, 04:25 AM
Hilux4Life's Avatar
Idler Pulley bearing goes out from time to time. I have just always replaced it with a new bearing from the dealership. Its real cheap, 8 bucks I believe. It is a actually very easy to replace too.
JNapolitano
11-14-2019 07:46 PM
Higbee89
08-27-2015 06:52 AM
kvanzandt1
07-18-2015 10:15 AM
razorman8669
07-12-2015 12:13 PM
mlavery85
07-12-2015 10:33 AM
Quick Reply: Does this sound normal? "Video inside"
