Does this look normal or excesive? (drain plug shavings)
Old 07-09-2007, 02:53 PM
SuaveGato's Avatar
Hello,
This came from the T-case on a 1991 4Runner 5 speed 3.0 with 150K (never been serviced as far as I know?) There were some more shavings inside that I was able to scoop out with my finger and a Q-tip but not too much more... And I will flush a little gear oil through it before final filling, to try and get most out. Does this seem like normal wear and tear for that year / mileage vehicle or is there maybe an issue with it?
thanks,
biGjOhn
Old 07-09-2007, 02:54 PM
tc
tc's Avatar
Looks normal to me.
What did the oil look like? Black, shiny...
Old 07-09-2007, 02:56 PM
Bigblock's Avatar
Normal
Old 07-09-2007, 03:08 PM
hodgepodge79's Avatar
that is a bit more than I have ever seen come out of my vehicles, but not excessive.
Old 07-09-2007, 03:14 PM
SuaveGato's Avatar
Ok, good. thanks guys. I haven't seen that much before either but then again, I haven't seen that many of them. That's why I figured I'd ask those who do see many. The oil looked "normal" more brown than black and consistency & smell were what I normally would expect to find. The rear however may have been synthetic? It looked more red than brown. I'm contemplating refilling all with synthetic? Right now I have the front & rear diff's, tranny & T-case all drained while I am replacing the clutch. Should I just use synthetic and be done with them for the next 100,000 miles or just use regular old Dino? It's NOT a wheeler, it’s G.F.'s DD.
thanks,
biGjOhn
Old 07-09-2007, 03:50 PM
MudHippy's Avatar
Synth or semi-synth oils are just plain better at protecting gears. I wouldn't go 100,000 miles without changing it though. Maybe 50k.
Old 07-09-2007, 04:16 PM
Tacotex's Avatar
[QUOTE=SuaveGato;50568996]Ok, good. thanks guys. I haven't seen that much before either but then again, I haven't seen that many of them. That's why I figured I'd ask those who do see many. The oil looked "normal" more brown than black and consistency & smell were what I normally would expect to find. The rear however may have been synthetic? It looked more red than brown. I'm contemplating refilling all with synthetic? Right now I have the front & rear diff's, tranny & T-case all drained while I am replacing the clutch. Should I just use synthetic and be done with them for the next 100,000 miles or just use regular old Dino? It's NOT a wheeler, it?s G.F.'s DD.
thanks,
biGjOhn[/QUOTE
Just checked the rear end oil in both of our yotas, and they both looked great. Next oil change (@45K), I plan to drain the Tacos rear end and tranny, JB weld some magnets to the drain plugs, fill with M1 gear oil (and TX7 in the tranny) and forget about it barring a flood or something. I recently did several creeks runs @ a TTORA event that put water up to the doors and saw no sign of water in the rear end. If I planned to do much more water like that I would consider running breather tubes to the airbox. If your GF will be done with the truck sooner than 80-100k miles, save your money
Old 07-09-2007, 05:06 PM
waskillywabbit's Avatar
Normal for sure.
Old 07-11-2007, 09:24 AM
TNRabbit's Avatar
My rear diff looked like that, only the shavings were finer (as in muddy DUST). The front diff, tranny, & xfer case all had NO particulates.
Old 07-12-2007, 11:07 AM
snap-on's Avatar
for as long as it was between changes.
normal
Old 07-12-2007, 11:11 AM
Kaydon's Avatar
You're good.
Old 07-12-2007, 12:08 PM
ewong's Avatar
In case you were still unsure..
NORMAL.
If the oil that comes out looks "glittery".. then you might have a bigger issue.
Old 07-12-2007, 02:37 PM
SuaveGato's Avatar
Kewl, thanks guys. Oil looked fine, no "glitter" etc. so I'll be refilling it and throwing it back in with no worries!
biGjOhn
Old 07-12-2007, 09:08 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
scary though, isnt it?
TN Rabbit, i thought you left us! I haven't seen a post of yours in a while, where have you been?
Old 07-15-2007, 12:49 AM
TNRabbit's Avatar
I've been REALLY busy with work; I'm in Phoenix right now until next Wednesday on business.
the1998sr5
15
07-14-2020 08:35 PM
kcaudill
07-20-2015 12:06 PM
daddio
07-18-2015 10:20 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Does this look normal or excesive? (drain plug shavings)
