do you know what this part is?
Please look at this pic and tell me what this part is. I have a 1995 3.slow runner. Also how importent is this part, and what does it do. Please help.
http://i40.photobucket.com/albums/e2...artforyota.jpg
That sir would be your dashpot...it controls your idle from what I hear. It keeps it from hanging up on rpms like if you're idling at 1200 rpm...and it should be idling at 750rpm, then that little gadget should let the throttle go down instead of stopping. It works in conjunction with the idle stop screw from what I have read.
Yep, the dash-pot is found only on manual tranny vehicles....it keeps the throttle from slamming shut when you let off the gas during gear changes....a shock absorber so to speak. It's an emissions thing....makes sure that last little bit of fuel gets burned up before the throttle closes.
At least its finally clean in there hahaha but yeah i was wondering in gods name that thing does too the inside is just a little foam filter with a cap.
its less of an issue when you're driving at highway speeds, but its for when you jump off the gas from a high throttle, to no throttle quickly to prevent backfires. If you ever listen to manual transmission cars racing you'll hear why they put em in, especally when they downshift coming into sharp corners.
Scroll down in diagram....DP....and it doesn't stand for something naughty either!
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
