Differential play
Old Oct 11, 2006 | 02:35 PM
silversup's Avatar
Differential play
How much should you be able to turn the differential/driveshaft before the wheels start turning? Should it be right away or a little bit of a turn b4 you can feel the gears engage. I turn mines and i get a little bit of play before I get any movement. I also checked the pinion nut and it was not coming loose.
Old Oct 12, 2006 | 08:30 AM
GSGALLANT's Avatar
A bit of rotational play there is normal, but there shouldn't be a whole lot if your gears are set up properly and in good shape. To try to quantify it, I'm thinking maybe a couple of degrees or so of rotation is normal? (Remember 360 degrees is a full revolution.)
Old Oct 12, 2006 | 09:11 AM
silversup's Avatar
i will check tonight. I had plans on checking out the transfer case.
Old Oct 12, 2006 | 11:24 AM
Flash319's Avatar
"If it aint broke don't fix it"
Old Oct 12, 2006 | 11:29 AM
silversup's Avatar
I wish that was the case. I am looking for the remainder of a vibration and noise issue I am having. Just did the U joints and it has gotten a little better.
Old Oct 12, 2006 | 01:02 PM
GSGALLANT's Avatar
You should have no vertical or horizontal play at the ends of your driveshafts (at the transfer and rear diff flanges). Check that and see if everything is tight.
Old Oct 12, 2006 | 07:11 PM
silversup's Avatar
OK here it goes. There was some play at the transfer case. The nut was loose so i tightened back to 87 lb ft. i gotta check to see if im still getting vibration at 50+ mph. Whats the worst case repair in having loose/vibration at the transfer case?
Old Oct 13, 2006 | 04:25 AM
GSGALLANT's Avatar
Depending on how long it was loose... I'd say possible bearing wear or seal damage. If it's not leaking, then you can rule out seal damage. In all probability though, you're probably OK.
Old Oct 13, 2006 | 10:11 AM
silversup's Avatar
Sounds good. I will see how it is when I hit 50 mph. I guess if I hear some noise/vibration, on will come the bearing change. I figure its a good time to change the transfer case fluid also. I will look for any flakes of metal.
Old Oct 13, 2006 | 11:52 AM
Flash319's Avatar
If it is an extra cab check the hanger bearing. Also check your rubber crossmember mount. I had the same thing and it was that one side of the mount came off. The rubber gets old and peels away from the mount.
Old Oct 13, 2006 | 04:53 PM
silversup's Avatar
I have the 95 4runner. Thats a good idea. I will also look over my mounts.
zytra
Jan 24, 2019 03:16 PM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
