Did a drop down bracket! Axle still out.
Old 11-19-2006, 07:01 AM
bullcrew's Avatar
I did a 3.5" (panhard) drop down bracket for the fj80 coils (short side rear) that I installed. The axle still protrudes out the passenger side 1" or more than the drivers side.
straight down 3.5 " from the other holes, this should have shoved the axle back under the runner.
I raised the proportioning valve up as well, it's fine.
Old 11-19-2006, 07:07 AM
Marc P's Avatar
Mine is the same. It doesnt bother me, and I haven't figured out a way to make it equal.
Lets see some pics of your rig....is it pretty level now??
Old 11-19-2006, 03:13 PM
FredTJ's Avatar
Originally Posted by Marc P
<SNIP>
<SNIP>
Easy....
Adjustable track bar.
Fred
Old 11-19-2006, 04:52 PM
bullcrew's Avatar
I'll post em probably tomorrow, the rear is approx 1" higher than the front. I put my roof rack on and my bike rack and still not level, i am going to remove 5" of coil wind and bracket the top to the frame. I cannot justify cranking the t-bars in anymore and MY GOD the articulation on the rear with longer shocks and no sway bar is insane.
Old 11-19-2006, 07:03 PM
FredTJ's Avatar
Originally Posted by bullcrew
<SNIP>
Put your rear sway bar back on.
All you have to do is fab up some longer links.
Fred
Old 11-19-2006, 07:30 PM
CJM
CJM's Avatar
What kind of shocks did you windup using?
Old 11-20-2006, 10:01 AM
bullcrew's Avatar
RMX (bilstein knock offs),
Old 11-20-2006, 10:05 AM
bullcrew's Avatar
Fred
Why! A sway bar limits it anywase, as long as I am not trying any high speed parking lot serpantine drifting (TOKYO drift aint got notin on IDAHO drift ) I should be OK.
I used to run a prerunner on the road and it had a lot more body roll than this does. Besides Then I have to disconnect when I go wheelin and make sure they dont get all bunched up in the frame or body or brake or spring or shock or somethin.
BESIDES: the body roll gets the wife car sick, so there for I don't have to carpool anyone!
Old 11-20-2006, 10:13 AM
bullcrew's Avatar
Sorry for the size, I still goof up trying to get it right in photoshop for best viewing.
Old 11-20-2006, 10:15 AM
Bill's Avatar
"ALL"
While links arn't the most complicated things in the world not everyone has a TIG welder(and knows how to use it) or the ability to precisley measure and cut the required pieces.
bullcrew: what the heck is written on the back of your Runner? ...rolling billboard-o-rama
Old 11-20-2006, 03:59 PM
bullcrew's Avatar
I have a sign shop! I do wide format printing/laminating contour cutting, vinyl lettrering, graphics backlit displays, stickers, magnets, vehicle/boat graphics.
Printed banners 1400x1400 graphics and vinyl as well.
Vehicle wraps!
And so on!
Old 11-20-2006, 04:14 PM
Marc P's Avatar
Looks good..need better pics though
Old 11-20-2006, 04:22 PM
Bill's Avatar
Vehicle wraps!
And so on!
Well, that would certainly explain it.
Out of curiosity, how well do those vehicle wraps actually stand up compaired to paint? I know, I know
Old 11-20-2006, 05:59 PM
bullcrew's Avatar
Really good, I did a full camo wrap on a buddies 87 x-cab toyota and it's had no issues. He hunts in the thickes brush etc... for bears,cougs etc. and it's still there.
Mine has seen a good amount of brush/branches and rocks flying up from the tires and no problems. 7 months on and still going even in the 110 degree heat over the summer and the sub zero's now.
Old 11-22-2006, 06:37 PM
Robinhood150's Avatar
This is what I've been trying to tell people for years on these boards. The panhard does not shift the axle over that much at ride height. Do the math and you will see that it physically cannot happen. It was like that before the lift. People just don't notice until after the lift and then assume it's because of the lift. Yes it will move it over a little, but it's a lot less than you'd think.
Old 11-22-2006, 07:52 PM
FredTJ's Avatar
"ALL"
I'm talking about some longer swaybar end links.
A 3' section of allthread and 4 studded rod ends, cutoff wheel or hacksaw and a drill and bits. Really easy.
BTW, you don't need a TIG welder to make control arms.
We do control arms, track bars, tie rods, drag links, etc., with a MIG.
I'ld venture that you'ld be hard pressed to find someone that uses TIG for that stuff.
Fred
Old 11-25-2006, 09:04 AM
bullcrew's Avatar
Fred
Any instructions on the longer sway bar links, Like how to!
I just drove to pocatello and back 1100 miles round trip (windy, snowy (extremely) uneven roads etc..) and it performed great and in controll. I did however notice that in 4X4 and on patchy roads the 4 runner would pull HARD to one or the other side and I would have to manhandle it to get it to steer. I have a Detroit True Trac in the front (lsd), is this just the way these things are or is alot of it not having sway bars on front or rear and its guiding the vehicle easier than if it had resistance from the swaybars.
Old 11-25-2006, 01:29 PM
slosurfer's Avatar
You did get an alignment done after the bj spacers, right?
Old 11-26-2006, 08:30 PM
bullcrew's Avatar
Yes and went back yesterday again to make sure it was still in alignment.
Sleaker
08-26-2020 06:03 AM
Doug4320
03-24-2018 10:11 PM
skoti89
09-11-2015 07:46 AM
coffey50
07-28-2015 10:55 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Did a drop down bracket! Axle still out.
