Decided to do the head gaskets
Old 03-30-2010, 09:53 AM
  #221
norcal707's Avatar
hey guys, could I still pass the smog test without replacing that valve.
Old 04-03-2010, 01:11 PM
  #222
budro's Avatar
this one oughta work
http://cgi.ebay.com/ebaymotors/toyot...s#ht_529wt_944
Old 04-03-2010, 01:12 PM
  #223
budro's Avatar
this one is for the 4runner but a bit more expensive
http://cgi.ebay.com/ebaymotors/Toyot...ht_2272wt_1202
Old 04-03-2010, 01:14 PM
  #224
budro's Avatar
when in ebay type into the search "bsvs toyota" and that'll get you the results that you need.
Old 04-03-2010, 01:15 PM
  #225
budro's Avatar
wups I mean "bvsv toyota"
Old 04-03-2010, 01:21 PM
  #226
budro's Avatar
Bi-metal vacuum switch valve... try to say that 5 times fast
and the llama rides on
Old 04-03-2010, 01:54 PM
  #227
norcal707's Avatar
Thank you budro....I got one from the dealer...$77 for it..couldn't wait to get my runner running just to find out a huge oil leak from the oil cooler behing the front driver side tire....any ideas for this
Old 04-03-2010, 03:48 PM
  #228
buckz6319's Avatar
Originally Posted by norcal707
thank you budro....i got one from the dealer...$77 for it..couldn't wait to get my runner running just to find out a huge oil leak from the oil cooler behing the front driver side tire....any ideas for this
oil leak not good:d
Old 04-03-2010, 04:15 PM
  #229
budro's Avatar
oil cooler? my 4runner doesn't even have one. is this aftermarket? if so can you bypass it until later?
Old 05-28-2010, 10:06 PM
  #230
betelnut's Avatar
Hey buckz, this is quite the thread you've got going here.
I take what I said earlier back:
Originally Posted by betelnut
The cam shaft retainer bolts stripping their threads sounds kinda worrisome, are you sure they stripped at only 12 ft-lbs?
Doing the HG on a friend's 3VZE, got the same thing on one bolt behind the #6 cylinder camshaft cap. Problem is that there's a locator pin there that the bolt goes through, so that bolt only gets about 4 threads worth of bite, compared to the rest that get closer to 10. Bit of a failure on the Toyota engineers' part. When I pulled the bolt back out, there was the spiral of aluminum that used to be the threads of the cylinder head, now wrapped around the end of the bolt.
Looks like there are lots of fresh threads down below. Thinking I'll get one of the longer cam cap bolts from the stealership and cut it down.
When I took the thing apart, the cam caps were torqued down way too hard. Rounded the heads of two of the bolts getting them off. Same with the cylinder head bolts. Can't believe the heads are still straight, but they are.
Old 05-28-2010, 10:12 PM
  #231
betelnut's Avatar
I just fixed this on mine. You'll need three gaskets that cost around $10 online (or $20 at your stealership's parts counter):
90301-61003 Base gasket
90210-22001 Gasket for the bolt
15785-35010 Internal gasket
If you've been leaking a lot of oil, check that the cooler's hoses are still ok. Oil makes them soft and weak and weepy.
15778-65010 Long hose
15777-65010 Short hose
Old 09-06-2010, 10:24 PM
  #232
gearsandgeardrivess's Avatar
Screw Jacks, Worm Gear Screw Jack Manufacturer and Suppliers in India
hi, I'm a silly spammer and I've been banned
good'ay!
kgcwb44
01-29-2023 10:02 AM
cars-guy
08-16-2020 06:59 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Decided to do the head gaskets
