cylinder block cleaning
Old Oct 12, 2006 | 02:24 PM
benwahballs's Avatar
I am preparing to get my heads back from shop, and want to clean up all the carbon and junk from the top of my cylinder block. I am worried about using a flange scraper as I do not want to scratch cylinder block. This is my first head removal & install and am just curious as to what other people have done to clean up existing gasket material, etc... Any tips, help, advice appreciated.
Old Oct 12, 2006 | 02:50 PM
GSGALLANT's Avatar
gasket scraper will work well. Just take your time and try not to get too much junk down into the coolant passages. I plugged a lot of the passages with bits of rags when I did mine a couple of weeks ago. If you do that, just remember to triple check that they've all been removed before you put the heads back on. I used a dremel tool with a brass brush to clean the tops of the pistons, too. I worked really well.
cars-guy
Aug 16, 2020 06:59 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
256mbaker
Jul 31, 2015 06:45 PM
kcaudill
Jul 20, 2015 12:06 PM
