Cruise Control Help
Old 10-25-2011, 12:51 PM
jvsr5v6's Avatar
Cruise Control Help
The cruise control on my 93 Pickup V6 doesn't seem to hold speed that well. It holds 55-60 mph but only on flat road. It will not hold 70-75 mph. I adjusted the cable but doesn't seem to help.
Anyone has this symptom? Thinking about replacing the unit from the junk, but not sure it thats the problem.
Any suggestions are appreciated.
Old 10-25-2011, 12:59 PM
RBX
RBX's Avatar
Probably the vacuum diaphragm thingy. I am not sure, but I know in older cars with a vacuum assisted cruise once the diaphragm wears out, it no worky.
Old 10-25-2011, 02:00 PM
Philbert's Avatar
Subscribing.....my 87 does this too - basically it's fine unless I'm going up a long hill - it will "kick out" and stop.
Curious if it's an easy fix, this diaphragm....
Old 10-25-2011, 03:19 PM
jvsr5v6's Avatar
Are you referring to the actuator or cruise control unit?
Old 10-25-2011, 03:28 PM
Philbert's Avatar
If you're asking me, i don't know!
just have the same symptoms as the OP.
Old 10-25-2011, 04:37 PM
BMcEL's Avatar
Probably the actuator diaphragm.
http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
kcaudill
10-10-2015 02:39 PM
Shagool22
09-28-2015 07:53 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Cruise Control Help
