Couple things
Old 11-04-2009, 04:15 PM
peow130's Avatar
Couple things
Few ideas.
I have the oil pressure gauge from an 83' toyota, the whole housing with the other gauge in it..
Can i make this guage work in my pickup?
Also, is it possible to make the heater fan go any faster?
I.e. Mod it
Old 11-04-2009, 10:26 PM
peow130's Avatar
nobody?
nobody knows if the oil pressure gauges are the same throughout the years?
Old 11-05-2009, 03:44 AM
akaphilly's Avatar
i think the idiot light better suites you. if u can handel it get the sr5 cluster ha ha ha
Old 11-05-2009, 05:02 AM
Fossilized
Staff
dropzone's Avatar
pop your vents off and suck the 20 years worth of crap that has fallen down there with a shop vac. that will help increase your air flow. plus it is free.
Old 11-05-2009, 06:35 AM
flyingbrass's Avatar
Also, clean out the blower itself. Might be full of leaves or other junk.
When the resistor goes bad you lose speeds other than high, so I doubt that's your problem. However, if all your speeds aren't working: http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
Old 11-05-2009, 09:51 AM
peow130's Avatar
No it's not that, i like it to have it on Feet/Window defroster. I always fog up my window on this setting.
Mkay, so all i need to change is the oil pressure sending unit?
@Ocd: Which vents? The ones up under the dash? Or the actual vents themselves on the dash.
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
HookahRoo
07-20-2015 07:06 PM
icentropy
07-14-2015 10:23 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Couple things
