Cold start problem??
i have been having a cold start problem jus in the cold mornings it takes forever to start, so my first idea was to test the cold start injector time switch, i took my voltmeter and put the positive on terminal STA (power) and my ground on terminal STJ (ground) on the sensor, then at 22 degrees i got 53.4 ohms, does anyone know if the sensor is good or not? or what are the specs on testing it?
I tested the wires up to the cold start injector and I have 12 volts and I unplugged the coil and turned it over to see if the cold start injector would spray and it didnt, so I figured I had a bad cold start injector I bought a new one and put it on and it still don't start easily, it takes forever, and I am getting fuel up to the injector any ideas????
What year is your truck?
On the cold start injector, the STA terminal is the hot ( 12v) and the STJ terminal is ground.
When you turn the key to start, power goes to STA, through the cold start injector( opening it and releasing fuel) and to ground through the Cold Start Injector Time Switch. When you do this you also send power to the heater elements in the cold start switch, which limits the time the injector stays open ( only a few seconds( depends on the outside temp). On some models the ECM can overide the cold start switch and keep the injector open longer. If the engine is cold and you dont have ground from STJ through the cold start injector switch, the the switch/ wiring is bad.
When testing, the engine has to be cold enough for the switch to be closed, if you dont do it quickly the heaters will open the switch.
< 10C (50F) = 30-50 ohms
< 25C (77F) = 70-90 ohms
I doubt this is a difference that makes a difference, so it looks like boostedyota's cold start timer at least passes that test.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
