codes 12, 14, 41
IG-7 is about testing the coil...
Look at your coil and find the -terminal (usually the one closest to the windshield), the + terminal (usually the one closest to the front bumper) and the 'HIGH-TENSION' terminal is the one that goes from the coil to the center distributor terminal. On most coils, the 'HIGH-TENSION' one is the the one that sticks the farthest out.
Do what tests it says, but yours don't look like it. Just substitute what you learned in my last paragraph.
What does your ignition coil look like? Mine looks kind of like a coke or pepsi can and has 3 connections on one end of it: two have little 'bolts' sticking up and some wires with little 'eye' terminals on them and one sticks out between the other two connections. It sticks out an inch or so from the top and the wire that connects there goes over to the middle of the distributor. My two little 'bolts'- one has a "+" sign next to it and the other has a "-" sign.
#27
sorry, been off in different directions
Anyways, even though your coil doesn't look like the pic, the terminals are the same. The + in the pic is the same as the + on your coil, the - is the same, and the 'high tension' terminal means the one that goes to your distributor. You'll be placing the meter probes on the appropriate terminal on your coil and measuring the resistance (ohms).
#29
ok well, between the positive and negative im getting nothing, or its open.
same as the high tension and positive.
so my guess would be i need a new ignition coil ??
#31
analog meter
scale ?
idk what you mean but the setting is at X10, so if i need .3 to to .5 that would be 3-5 ohms
the needle isnt moving
scale ?
#35
i think that when we first got it, it had one, my dads buddy did a HG job but never followed up to re tourqe the head, and i overheated soon after due to a bad waterpump gasket and not knowing about it.
bummer.
hopefully thats where all my oil is going and this thing isnt burning as much oil as i think (4 quarts in 600 miles)
bummer.
#36
well if the oils going into the cooling system, you'll see it floating on top of the coolant in the radiator- remove the rad cap and it'll be there.
but if you're going to be in it for a new HG, you might as well pop the pistons out the top of the engine and mic the cylinders checking for taper and wear. It's possible that the HG was done just to hide a problem and the engine actually needs rebuilt.
Wish you luck!
Wish you luck!
#37
gahhh
well if so, i have a spare 22re that was in my old totalled truck that would be ripe for a swap, its only got 80k on the motor .
so if it does need a rubuild, then the swap is prolly going down, thats what i want anyway
#38
As said, good luck.
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
