clock& radio goes out when started and shifting problems
Old 03-05-2013, 04:29 AM
jawnboy's Avatar
94 4runner 180k miles 3.slow AT
bought this truck last week, changed the fluids and observing the truck for other problems .. (i think i might need a headgasket soon)
started it today, the clock and radio would light up when i turn the key but when i started it both of them turned off.
shut off truck and did process again .. same thing
then i put turck in drive, it shut down, i put it back in park it starts up again(?) did this a couple of times .. i noticed that whenever i hit Neutral it shutsdown but Park Drive and Reverse it starts up .. its magic ... scary magic
any help and advice would be appreciated
Old 03-05-2013, 07:24 AM
scope103's Avatar
I'd start with the Park-Neutral switch http://personal.utulsa.edu/~nathan-b...34electron.pdf . You should never be able to start it in Drive/Reverse.
You could have a bad ignition switch. The clock/radio are on in "ON" position Engine-Off, but turn off in the "ON" position with engine running? Does your "Batt" light work (on when Engine-off, off with Engine-running.)?
Old 03-05-2013, 07:56 AM
jawnboy's Avatar
funny, started truck again 10 mins ago everything works fine now ... clock light and radio are on when engine is running, tried changing gears and no stalling ...
but yes prior to it running normal again, the clock and radio go on when the key is in the ON position, but once started they both go off. Battery light lights up when key is in the ON position
and fwiw it stalled when i hit neutral but once i shift it into D the engine starts by itself ... true story same with R and P
Yota.Jay
03-06-2016 11:02 PM
vasinvictor
01-20-2016 12:39 PM
aciorba23
06-29-2015 04:18 PM
scott
07-15-2002 07:56 AM
Lowviz
07-04-2002 09:43 PM
Quick Reply: clock& radio goes out when started and shifting problems
