Clank in driveshaft while starting in reverse
The truck is an '89 Xtra Cab with the 3vze, 5 speed, and stock 4:10s.
In the last six months, I have replaced the clutch and all associated components..
For the last couple of months, whenever I go from nonmoving to reverse, the truck hesitates for half a second, then something underneath makes a loud clanking noise. Right after the noise, the truck moves in reverse like normal..
This clanking/hesitation only seldomly happens, nor does it happen more while the truck is warmed up or still cold. The FSM doesn't point in any direction, unless I managed to reinstall the rear driveshafts without properly aligning the four bolts, but I don't believe that problem would only produce evident problems in reverse..
Any ideas?
Any ideas?
Most likely, you can slide underneath, and if you can turn the driveshaft more 10 degrees, or push the driveshaft sideways more than 1/4", something's wrong. Just find the place where there is slack (most like one or more u-joints, but it could be the support bearing).
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
