Choice to be made
Old 02-27-2013, 05:00 PM
yotajedi's Avatar
Exclamation Choice to be made
So the info is. I have a 94 v6 auto tran ADD 4x4 sitting on 33 tires with a 4 inch lift Yes it is done right. The truck has 3.91 gears stock.
I need to do a regear as this thing is a slug with no balls.
I am thinking 4.88 or 4.56 gears.
Now I can get a set (front and rear) 4.56 from a pull yard for 323.00 out the door already pulled.
Or I can drop 800-900 on the gears for the 4.88 gearing.
This truck is a daily driver so MPG has to be kept in mind. So does highway driving.
My first thought is go with the 4.56 gears as they are the best of both worlds mpg and hill climbing.
The 4.88 gears are the best for off raod and hills, but not so good on the mpg and highway as it will rev higher.
This is the issue at hand. I only have a day mabe two before that yard sells that third member it is the only one in the area.. They fly off the shelf around here. Plus you never find a 4.56 in a yard they where special order on the 4 runners ( which is what it is coming out of) (Going into a 94 pickup)
Any thoughts or help would be great.
Old 02-27-2013, 05:05 PM
NickMiller's Avatar
Personally I'd hold out for a good deal on a set of 4.88 third members because us auto tranny guys need all the help we can get. The highway MPG should still be decent even with the 4,88's. 4.88's are what most people would recommend for 33's anyway
If you don't want to wait for the 4.88's, the 4.56's will be a nice little boost from 3.90's.
Old 02-27-2013, 05:50 PM
yotajedi's Avatar
I hear what you are saying 4.88 is a must for the 35 tires but it seems to be on the line for the 33 tires. With 33 tires it turns the 4.56 into a 4.86 gear.
Now the auto does take a little more help. But that would put my gear with the 33 tires over 5.0 and the rpms would scream on the highway.
Old 02-27-2013, 06:09 PM
vasinvictor's Avatar
I thought 3.90s are only in older generations and the 2wd 2nd gens. What's your axle code?
Old 02-27-2013, 06:12 PM
yotajedi's Avatar
B06B fremont plant
Old 02-27-2013, 07:44 PM
yotajedi's Avatar
Forgot to point out that the 4.56 would be coming out of a runner with abs, does this effect it go into a non abs truck.
Old 02-27-2013, 07:47 PM
Doesn't matter. You'll want to be sure to snag the abs sensor though to plug the hole.
Old 02-27-2013, 07:51 PM
yotajedi's Avatar
What can I use to plug the hole other then the sensor. I don't get to take the unit out it is a they pull the part place. Could I use a bolt or something else?
Old 02-27-2013, 07:57 PM
toyota4x4907's Avatar
An engine freeze plug might fit, not necessarily from a Yota. Im sure there is some kind of after-market block off somewhere
Old 02-27-2013, 08:19 PM
http://bit.ly/WsJhBr
This is what you will be missing. You could make something easy enough.
Old 02-27-2013, 08:24 PM
yotajedi's Avatar
Thank you for pointing that out. I will see what I can to get that sensor. It is on the front diff right?
Old 02-27-2013, 09:27 PM
Abs is on rear diff only.
Old 02-27-2013, 09:31 PM
yotajedi's Avatar
OK thank you for your help.
Old 02-28-2013, 03:33 PM
yotajedi's Avatar
Ok i went with the 4.56 for right now. I am keeping the 3.91 diff's to change them to whatever gearing I go with a few yrs down the road. Thank you all for your help.
Old 02-28-2013, 04:31 PM
JonnyBoy's Avatar
Here you go for the abs hole in the Runner diff
http://www.lowrangeoffroad.com/index...eeze-plug.html
Old 02-28-2013, 05:58 PM
nothingbetter's Avatar
I think you made the right call going with the 4.56 gearing. If they're gone as quickly as you say they are, you'll have no issues selling them if you deicde to re-gear in the future.
Old 02-28-2013, 06:34 PM
yotajedi's Avatar
Thank you
ashamsuddin
17
01-13-2023 03:17 AM
SpookyMulder
11-04-2015 11:56 AM
White Stripe
10-06-2015 10:47 AM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: Choice to be made
