Chirping sound under hood
Old 11-01-2007, 03:33 AM
gt0987's Avatar
I hope someone can diagnose or help from my description. I haven?t had time to get pics yet.
I have an odd chirping sound from under my hood. It seems to come from a component on the front, driver?s side of the engine, up at the top of the engine. I expect it does it all the time but I only hear it at lower RPMs with less noise.
I thought it might be something with the EGR but it looks like those components on the passenger?s side. Could it be something with the cold start injector?
I?ll add pictures to the post as soon as I can.
Thanks.
Old 11-01-2007, 03:53 AM
GSGALLANT's Avatar
some details on what you have for a vehicle and which engine you have would be helpful. Add that info to your signature so that it shows up with all your posts.
Old 11-01-2007, 04:43 AM
gt0987's Avatar
Holy crap! I can't believe that I left that out. You mean you guys can't look at my screen name and use your ESP to fill in those minor details?
It's a '90 pick-up, 5-spd, 3.0L, 4x4. Only minor mods of 1" body lift (added yesterday and chirping was already going on), TJ helper coils, and torsion bar adjust to level out the front.
Old 11-01-2007, 05:48 AM
cadman's Avatar
My wife's 4Runner makes a chirping sound from the front end near the steering gear box and it turns out to be one of the clips that secures the grille is broken. The grille in that area vibrates at certain speeds and sounds like a small bird.
Old 11-01-2007, 06:03 AM
Firebb15's Avatar
Well first off...did you check your belts?
Old 11-01-2007, 07:24 AM
gt0987's Avatar
When I listen to the engine running the sound is not coming from the belts. It's behind them (closer to the driver) and seems to come from a component. I haven't been able to find a good picture of it, or that general area under the hood, on the web so I'll have to take one tonight and post it.
As far as the belts go they look ok. No splintering, no cracks, good tension, they have about 25-30k on them.
Old 11-01-2007, 11:33 AM
KevinInSac's Avatar
Tried using the screw driver/thumb trick to listen to all of the components? You might be able to find something out that way.
JNapolitano
11-14-2019 07:46 PM
Marsheen
02-17-2016 12:29 PM
zombie_stomp
08-30-2015 10:26 AM
AppalachianOffRoader
08-12-2015 12:55 PM
romex1
08-10-2015 06:21 PM
Quick Reply: Chirping sound under hood
