| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Checking Codes on a 91 4runner?
#2 (permalink) | |
Quote:
#3 (permalink) |
Yes, but I dont want you to lose an arm or a leg. Have you tried Pep Boys? I know it will take over 30 seconds to go into Autozone and listen to the guy tell you he cant do it.
__________________
Toyota Master Diagnostic Technician "MDT" 1998 Toyota Tacoma TRD V6 4WD 5 SPD 1998 Chevrolet K1500 1999 Toyota Camry 2003 Toyota Highlander 4WD 2007 KTM 85SX 17/14 2006 KTM 300XC-W 2005 KTM 65SX 2004 Kawasaki KLX 110 2003 Honda XR50 2002 Yamaha TTR 125L 2002 Kawasaki KLR650 2002 Suzuki Eiger 400 4WD 2004 Cargomate<--link GeePaw® Racing<--link |
#4 (permalink) | |
Quote:
if you know just say so. when you do like above more than the person who originally posted that got your ire up suffers from your post. If you don't care for the negative dealer comments PM them and change their mind. I have read almost every post you have done in the last few weeks and have learned quite a bit, and will hopefully continue to glean some info from your experiences. You have posted some very useful info. Don't muddy the waters by trying to but heads with the haters. sorry for the rant , back to the regularly scheduled program.
__________________
'83 Truck 4x4 - 4" lift, downey header,, lots of stickers. '90 Runner $600 project ,32's on black Steelies,Optima Red Top, 1.5" Balljoint Spacers, 80 series Coils, Sleeping/Storage Platform extravaganza You know enough to be dangerous, get out the way before you break something i can't fix- Pops Bah, you are such a moose... Rota est Fun! http://www.4x4support.com |
#5 (permalink) |
You have to admit that most dealerships are the most expensive places you can go to have service done on your truck. I do all the work on my truck myself but occasionally go to the dealership to order parts. I'm confused by what your post meant, but when I go to the dealer they are usually less than helpfull if I have questions. I see that you work for a dealer but don't be offended by my post and take it personal as I was not talking about you or the dealership you work for.
#6 (permalink) | |
Quote:
#7 (permalink) |
I think he means it will be a two digit code Like 10 or 25. the first set of blinks will be the first digit 1 the pause then the next set will be second digit 7.
__________________
#8 (permalink) |
Yes...it will blink twice...then short pause...then maybe blink 5 times...that is read as code 25. Now...keep watching it because the codes repeat themselves and be sure you are reading the code correctly. There will be a longer pause in between blinks when the code is finished. Like this...
Blink blink...blink blink blink....................blink blink blink That would be a code 25 and 3 just for an example. Best way I can explain it.. |
#9 (permalink) |
How to check codes:
http://www.4crawler.com/4x4/CheapTri...CheckConnector
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
So I checked the code today with the paper clip, That was awesome! I couldn't believe something so simple worked. I came up with a code 71 witch is the egr system. A dealership had told me before that it was either the egr modulator or the egr vacuum switching valve (VSV) I have already replaced the modulator and the light is still on, but before I just start buying more parts I was wondering if anyone else here has had any expierience with this code and what it was. I looked in my manual to find my VSV a month or so ago and couldnt find it. Thanks for the help so far guys.
#12 (permalink) | |
Quote:
#13 (permalink) |
How much suction does it usually take to make the motor die? I sucked as hard as I could (hahaha I can't help but laugh) but at the most the engine just seemed to slow down a bit, but not die.
#14 (permalink) |
Forgive me if I'm being Captain Obvious, but you did clear the code right? (By pulling the neg battery cable or pulling the ECU fuse) It just concerns me when you say "still on" as the code won't go off till you clear it. When the code comes back on that you know you have not fixed the problem.
Good luck- -Scubaduck |
#15 (permalink) | |
Quote:
Mine slowed the motor way down and died...might have a leaky EGR valve. |
#16 (permalink) | |
Quote:
#17 (permalink) |
yeah I have cleared it since replaceing the egr modulater and its come back.
#18 (permalink) |
I hate to buy a new egr just to find its not the problem, if I remove it is there any obvious visual sign that it isn't working?
#19 (permalink) |
I would think now...it will still throw a code if removed. Go to a junkyard and buy one. They are over $100 new, but you could maybe get lucky with one at a junkyard.
#21 (permalink) | |
Quote:
An EGR valve is spendy, and prety easy to replace. Holler if you need more help.
__________________
#23 (permalink) | |
Quote:
#24 (permalink) | |
Quote:
I also might add, I mentioned shorting the EGR gas temp sensor pins, this doesnt fix your problem (inop EGR) it just makes the engine ECU ignore the EGR system. In fact, non cally models had a factory short pin plugged onto the ERG gas temp sensor wire. So it will never set that code again.
__________________
#25 (permalink) | |
Quote:
Some good info there! Did not know they had the temp senders on all after 93...my bad! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Checking for codes | Robrt32 | 86-95 Trucks & 4Runners | 5 | 06-09-2007 08:59 PM |
| 91 22re CEL codes | TurboKH | 84-85 Trucks & 4Runners | 4 | 12-29-2006 03:54 PM |
| Help Check Engine Cel codes Trans codes Brake codes | NicksBlue934runner | 86-95 Trucks & 4Runners | 2 | 04-26-2006 05:35 AM |
| Checking codes on an 89? | mtrdrms | 86-95 Trucks & 4Runners | 1 | 04-03-2006 02:03 PM |
| checking trouble codes | Robinhood150 | Maintenance & Repair Archives | 1 | 06-15-2002 01:58 PM |
