chasis ground strap
Old 12-04-2008, 08:05 AM
jms3251's Avatar
chasis ground strap
yes i just dropped a motor into a 93 pickup, we got evreything hooked up and tried to start it and nothing, we checked all the fuses and they were good, i have dash lights and evreything it just wont turn, the starter wont even bump. we got it tested and it was good. a freind of ours says it might not be grounded and to try the jumper cable trick but still nothing. i was wondering if anybody knew where the chasis ground wire is on a 93 4x4 pickup with a 22re and if anybody had any ideas to what it might be. also we tested the wire that goes to the solenoid and its not gettin any power.
Old 12-04-2008, 08:26 AM
Staff
DeathCougar's Avatar
The negative battery cable grounds straight to the block, so check that.
There is also a ground wire from the rear engine hook to a bolt in the upper middle of the firewall. That grounds the engine to the chassis, and there is also a smaller wire that comes off the negative cable and grounds to the core support.
Old 12-04-2008, 10:09 AM
jms3251's Avatar
we have all of those grounds hooked up and still nothing
Old 12-04-2008, 10:13 AM
TNRabbit's Avatar
ignition/key issue in the steering column?
Old 12-04-2008, 10:19 AM
jms3251's Avatar
ground strap
i dont think so because right before we pulled the motor it was working great with no problems but now nithng, all the dash lights come on and radio and evreything but the starter just wont bump.
Old 12-04-2008, 10:21 AM
Elton's Avatar
id go back over and check all the wires
Old 12-04-2008, 10:23 AM
TOYOTA 1's Avatar
hmm... you need to figure out why there is no power to that wire..(you probably already know that lol).
you could bypass that wire and just run a hot one to a switch or just touch it to the batt, that wont fix your problem but ill bet it will start
Old 12-04-2008, 10:24 AM
jms3251's Avatar
we did and evrey one of them gets power except for the one that one black and white one that runs down to the solenoid. we traced it all the way up to the fire wall and even when you turn the key to start it gets no voltage.
jms3251's Avatar
yes i thought about doing that but i probably would end up starting a fire
Old 12-04-2008, 10:27 AM
Staff
Since its obviously not a grounding issue, you can move on to step two. Check all your connections, make sure everything is tight, make sure the cables are hooked up and tight, etc.
Btw have you tried bench testing the starter? perhaps the contacts have gone bad inside the starter.
Old 12-04-2008, 10:42 AM
jms3251's Avatar
we had the started tested at advance and it was good, i will go over the connections again.
Old 12-04-2008, 04:42 PM
jms3251's Avatar
still more problems
well i went over all the connections and all of them were good except for the coolant temp switch, i am getting one tomorrow but i dont think that it has anything to do with the engine starting, am i wrong? also just to double check it i added another ground strap and still nothin so i am sure it is grounded.
Alexdosdall
12-10-2017 05:48 PM
live4soccer7
05-11-2016 06:52 PM
Obmi
10-04-2015 11:30 AM
hiluxinargentina
09-30-2015 05:51 PM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: chasis ground strap
