Carb ?
Old 06-25-2014, 11:00 AM
Rusted Rooster's Avatar
Carb ?
1986. 22r. Carb won't hold gas overnight. No other issues.
Old 06-25-2014, 02:22 PM
wyoming9's Avatar
Red face
Where does it go??
Is it draining down into the engine?? Ending up in the oil??
Bad needle and seat valve and a strong vacuum in the tank?? drawing the gas back through the fuel pump??
Old 06-25-2014, 03:09 PM
Oil is fine. No external leaks. Pretty sure
Fuel in draining back in fuel tank. After it
Sit for a day or two
Old 06-25-2014, 11:11 PM
wyoming9's Avatar
Red face
It would seem your fuel tank is not venting through the evap system creating such a strong vacuum.
This creates a siphon effect if in fact it is not draining into the engine.
You have pulled the Top off the carb and have seen this??
Then because of the no fuel and mechanical pump it cranks very long before starting??
This is all a guess been a long time since I had a Toyota with a Carb.
Old 06-27-2014, 10:55 AM
Thanks
Thank you for info Wyoming9. EFI IS SWEET.
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
the_supernerd
10-01-2015 09:20 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Toys4parts
09-26-2015 01:56 PM
taraf
09-25-2015 02:57 PM
Quick Reply: Carb ?
