Can't separate t-case from transmission
Old 12-14-2013, 04:22 PM
4X4XFAR's Avatar
1992 22RE 5-speed
We attempted to remove t-case (forward shift) without removing transmission from truck
Can't get it off further than about an inch away from transmission
Seems to be hung up on shift rails
Is there a trick to this?
Old 12-14-2013, 05:33 PM
Cyberman's Avatar
Did you remove the shifter?
Old 12-14-2013, 05:52 PM
4X4XFAR's Avatar
No, the shifter was still in place.
Old 12-14-2013, 07:03 PM
85toy4runner's Avatar
you need to remove your transfer shifter from trans so it can be removed. those forks that you see in the pic go into the trans and the transfer shifter locks it in
Attached Thumbnails Can't separate t-case from transmission-forwardshift.jpg
Old 12-14-2013, 07:12 PM
4X4XFAR's Avatar
Thank you . . .
briholt
09-20-2015 10:26 PM
Ott47
09-14-2015 12:09 PM
eggens
09-05-2015 12:16 AM
kelly1450
09-02-2015 12:29 PM
Quick Reply: Can't separate t-case from transmission
