Can you remove a transfer case without removing the tranny?
Old 05-17-2009, 06:36 AM
fordmgt1's Avatar
My FSM and Haynes manual says that in order to remove the transfer case, the transmission must be removed. I have an 86 runner I'm putting a doubler kit on, could I just place a jack stand under the transmission and then remove the transfer? Thanks for the help.
Old 05-17-2009, 06:46 AM
waskillywabbit's Avatar
Yes, you can do it that way. Just make sure you support the tranny well.
I just pulled one last night and just dropped crossmember and all and then separated.
Old 05-17-2009, 06:48 AM
fordmgt1's Avatar
Thanks, I know I could count on you for an answer!
Old 05-17-2009, 06:50 AM
Make sure you got the right kind of reduction box to match your tranny, i.e. if you have a forward shift tranny you need a forward shift reduction built (shift forks are different) and that you have the right shift forks/rails. I wasn't paying attention and just assumed what I had and ran into some junk yesterday. Nothing I can't fix but just a pain since it wasn't expected.
Old 05-17-2009, 09:15 AM
fordmgt1's Avatar
both cases have shifters mounted to the top, so I assume they are right... at least I hope so.
Old 05-17-2009, 09:50 AM
Staff
DeathCougar's Avatar
those would both be top shift cases then.
Old 05-17-2009, 11:35 AM
toyNG's Avatar
When I removed mine, it definitely didn't just pop off really easily. I had to persuade it a bit by wiggling it around and beating it with a rubber mallet. I love rubber mallets! Beat as hard as you want with no worries of damage!
PNWrider
10-30-2015 08:14 AM
ViperTT
08-14-2015 05:27 AM
yourrealdad
07-29-2015 11:08 AM
SMOD
07-23-2015 10:29 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Can you remove a transfer case without removing the tranny?
