cam selection for 22RE
Old 07-04-2007, 10:00 AM
skife's Avatar
I bought this cam, http://store.summitracing.com/partde...&view=1&N=700+
didn't realise after i got here the cam sheet says "not for computer controlled engiens"
will this work anyways on my EFI motor, i know other people are using a cam with about the same specs as this only the cams they are using are a split duration.
also on the cam sheet it says "valve springs required" does this mean i need different springs or will the stock be fine?
thanks for the help.
Old 07-04-2007, 10:42 AM
tedfrk's Avatar
if it was me i would call summit to see what they say
Old 07-04-2007, 04:50 PM
skife's Avatar
i'm just goign to use it, someone else is using a very very similar grind and other people have used this before .
RatOmeter
10-22-2015 03:17 PM
Iceman4193
08-28-2015 08:43 PM
nonstop
7
08-11-2015 09:26 AM
Fakayayou
08-09-2015 12:47 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: cam selection for 22RE
