Bypass the neutral safety switch??
Old 08-08-2012, 09:31 PM
Punchy's Avatar
Also check the starter relay in the engine copartment fuse box, Swap it with the AC relay if you have to.
Old 08-08-2012, 11:04 PM
my90yota4x4's Avatar
@rad4runner thnx I'll have to check simple things first before I start spending money on the wrong things haha
@punchy would that have something to do with it??
Old 08-09-2012, 04:27 PM
RAD4Runner's Avatar
Always a pleasure to help.
Yes, starter relay powers the starter solenoid. As suggested by scope103, and as I detailed in my post above, check it.
If you suspect the start relay and IF AND only IF AC relay is same part as starter relay, go ahead and swap them, as punchy suggests. If swap fixes it, OK to suspect your starter relay.
Old 08-09-2012, 07:59 PM
@Rad4runner cool man thanks I'll check that out tommorow hopefully its that relay
Daenerysdad
10-01-2015 07:33 PM
EatChipsNow
09-09-2015 01:25 AM
zz_denis
09-06-2015 03:43 PM
LJR
09-05-2015 06:02 AM
kelly1450
09-02-2015 12:29 PM
Quick Reply: Bypass the neutral safety switch??
