Broken Temp Sender?
Old 01-11-2014, 01:45 PM
pascoscout's Avatar
Broken Temp Sender?
My temp gauge in my 1988 4runner (3.0V6, SR5) started acting up.
It was working ok, seemed like it always sat at 1/2 way after just a few mins of driving. I had to replace the speedo cable so while I had it out I thought I'd check out the wires on the temp gauge (as done in definitive temp gauge fix sticky). Didnt find any broken wires but did see some corrosion starting and a small glob of solder on the copper wires themselves. Cleaned off the corrosion and removed the solder (seemed like it didn't belong thought it was just a drip from assembly).
Now when I start the truck it reads cold like it should. But after only 1 mile (maybe 1-2 mins) of driving it goes from cold all the way up to the bottom of the red zone. Never goes higher than that. If I pull the plug off at the sender it drops back down to the bottom. I checked the engine temp with my infared tester and am seeing 180-190 at the block and T-stat housing so don't think its acutally running hot. The upper rad house and radiator are 170ish.
Could the sender be bad or did I screw up by removing that tiny drip of solder?
ladybugRC
458
08-21-2020 10:41 AM
punks_is_4x4
02-26-2016 04:29 PM
bradahman
10-01-2015 09:24 AM
Brodetski
09-30-2015 11:50 PM
rmill05
09-27-2015 01:43 PM
Quick Reply: Broken Temp Sender?
