Broken ground wire location??
I found this broken ground wire on my firewall right behind the valve cover and cant tell where it used to connect to..anyone recognize? its the kinda out of focus wire in the pic grounded to the firewall, and the other pic is just the broken end of it.
there is a plate on the back of the head for the EGR passage, the other side of that wire is connected to one of those bolts. If you can't get to it, you can bolt it to engine lift hook that is at the back of the engine as well.
That ground back there is so little I can`t see that it does much.
Other than the ECU ground on the intake manifold and headlights etc I just have 2 major grounds in the engine compartment one to a inner fender bolt and one to the engine block.
This is about the first thing I do to these vehicles upgrade the grounds.
the1998sr5
15
07-14-2020 08:35 PM
88yodabasket
07-13-2015 01:32 PM
jon.r
07-11-2015 03:34 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
