Broken antenna
Old 10-10-2009, 07:34 PM
explodingchimp's Avatar
Broken antenna
My FM/AM radio antenna is broken. I still get a signal but the antenna itself is very loose, and the sound is full of static. Has anyone done a replacement of this and would like to share advice? Do you have to remove the fender, or just go up through the wheel well? Any help is appreciated!
Old 10-10-2009, 07:52 PM
flyingbrass's Avatar
x2 on this question.
Mine had been bent back for a long time and finally broke off.
How do you get to the thing, and are any bolt-on flexible replacement antennas available that fit the stock hole? I have an 86 pickup.
Old 10-10-2009, 08:02 PM
deserthound's Avatar
Remove the plastic liner inside the wheel well. The bolts that hold the antenna in place are then accessible. This is for a power antenna. The top of the fender part of the antenna also has a special nut to remove to allow the antenna shaft to drop down into the area where you removed the plastic liner. Hardest part is re-routing the cable back into the cab.
ladybugRC
458
08-21-2020 10:41 AM
punks_is_4x4
02-26-2016 04:29 PM
zombie_barbarossa
10-02-2015 10:54 PM
bradahman
10-01-2015 09:24 AM
Brodetski
09-30-2015 11:50 PM
Quick Reply: Broken antenna
