Brake Light is always On
Old 04-01-2007, 04:12 PM
Guardian_Saint's Avatar
Hi there YT, recently I made a little car accident and causes the other car a total damage of $1k+ and mine has no damage, only the grill was a bit bent so np at all, but as I notice the brake light on the dash is now constantly on now. So whats wrong? I try the search but came up nothing so if anyone know what is it then reply or PM me, thanks. The brake do not squeak or fill any braking issue just normal, and have check e-brake and has 15 clicks on it so it should be fine as the FSM indicate.
Old 04-01-2007, 04:18 PM
WATRD's Avatar
Fill up the brake fluid.
Yes, it looks full... it's not. Just top it up as much as you can and the light will stay out.
Old 04-01-2007, 04:35 PM
operose's Avatar
funny you say that... that is the exact cause of this problem on my girlfriend's 99 corolla. brake fluid was "full" but the light wouldn't go out until I put more in it
Old 04-01-2007, 04:38 PM
WATRD's Avatar
It the #1 reported Toyota "problem". There are probably 50 threads on here about it. Well, make that 51 now
Old 04-01-2007, 11:41 PM
shoes138's Avatar
if i was u i wouldnt top it off! it prolly means that you need to change your brake pads, that would be the only reason why the brake fluid would be low or if there is a leak.
Think about it if your brake pad is lowe then your gonna have to use more hydrualic fluid to pust the piston out more to make the brake pad touch the rotor!
Old 04-02-2007, 12:49 AM
operose's Avatar
I thought that too with my girlfriend's corolla, but all four pads were FINE
why do these yotas drink brake fluid?
Old 04-02-2007, 12:52 AM
ovrrdrive's Avatar
Mine has leaked brake fluid since it was brand new. They just "could never find the leak" when I took it in so it still leaks to this day.
Of course, now after 200,000 miles I can spot the leak I'm just too lazy to reflare the pipe and fix it.
When the light comes on I just top it off.
Old 04-02-2007, 01:53 AM
operose's Avatar
my wise old dad said it could be a bad seal in the master cylinder
Old 04-02-2007, 10:34 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
It's probably just gremlins...darn them.
Old 04-02-2007, 10:38 AM
UncleBob's Avatar
What about the E-Brake microswitch?
Old 04-02-2007, 10:42 AM
CJM
CJM's Avatar
Fluid, your brake pads are not low. It may have lost some fluid somehow..does happen.
Old 04-02-2007, 10:48 AM
thook's Avatar
Maybe the MC cap got knocked loose in the wreck and spilled some brake fluid?
Old 04-03-2007, 07:35 PM
Okay, today I fill it up which is not that low and the cap is not leaking from it either and the light is still always on, ever since I made that small accident. Maybe it move the brake caliper? Need adjustment? I don't know. The braking is fine and it appear the two front rotor is fine w/o any scratch at all, I am guessing the rear brake maybe the possible cause to be on so maybe next month I will have it in service. I'll check some of you guy's tought on this one so Thanks for the replies YT member's.
Old 04-03-2007, 08:43 PM
91TPU's Avatar
haha like when were at paragon lol...i would def top it off, i had the same issue last weekend, and this was the cause...good call marc, saved me some time, and some worry!
Old 04-04-2007, 01:27 PM
BeaterToyota's Avatar
How long has the brake light been on? How long since the accident?
The reason I ask is that the brake light will come on when the alternator isn't functioning properly. Usually this is accompanied by the "charge" light also, and in your case it doesn't sound like that's happening. Anyway, it might be worth checking the alternator and all of the cables leading to and from it and the battery. Something could have been corroded/loose, and the accident could have made it loosen up even more.
Old 04-04-2007, 01:40 PM
ShortyzKustomz's Avatar
check and see if the ebrake rod is hitting the switch, my light wouldnt go out and the thing just wasnt hitting the switch
Old 04-04-2007, 01:46 PM
thook's Avatar
Right....good call.
Old 04-04-2007, 01:48 PM
GV27's Avatar
There are only two switches associated with that light. So discounting other electrical gremlins, it's either the e-brake switch or fluid level switch. It's one or the other. So it's not the adjustment on the brakes, not the condition of pads or rotors or anything else. One of those two switches.
Old 04-28-2007, 06:35 AM
racehound's Avatar
brake light
I had this problem & found that the pin that attaches to the emergency brake handle and hits the switch had fallen out.Glued it back in & all is well.
Old 04-28-2007, 12:11 PM
celica860's Avatar
Funny I stumbled across this, my brake light has been on since I bought this thing and I topped the fluid off yesterday and it hasn't been on today :-).
ashersullivan88yota
01-18-2022 05:37 PM
fountain
12-31-2015 06:08 AM
09-04-2015 09:27 AM
Sandman
07-14-2015 12:36 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Brake Light is always On
