BJ spacers
Old 07-23-2009, 05:25 PM
93YotaMonster's Avatar
BJ spacers
hey guys im ordering some 1.5" BJ spacers tomm, how long of shocks do you think ile need? my t bars are cranked from previous owner witch im going to leave. i no the ride qulity iseant going to be that great. my truck is a 93 toyota pickup 22re.
Old 07-23-2009, 06:14 PM
mattaway's Avatar
measure your stock shock and add 2"
Old 07-23-2009, 06:16 PM
Dipstik_90's Avatar
Say goodbye to your CV's and any on road handling and ride. I have 32's on my truck and it's stock with no rubbing.
Old 07-23-2009, 07:05 PM
Matt16's Avatar
Or get an alignment dipstick.
Old 07-23-2009, 07:11 PM
waskillywabbit's Avatar
http://www.wabfab.org/products/IFSlifts/IFS.htm
Old 07-23-2009, 07:17 PM
say goodbye to my cv's? that's why they make a diff drop to help with the excessive cv angles. plus i dont do a lot of hard core wheeling so im not going to worry about it.
Old 07-23-2009, 07:58 PM
OutlawMike's Avatar
Check 4Crawler.com, he has some shock recommendations on there and tells how to shim them with washers if they are a bit too short.
Or, wait until Sunday night, I am installing my 1.5" ball joint spacers Sunday morning. I will tell you how the OME front shocks work out.
My buddy and I did the rear OME Dakar springs, OME shocks, and 5.29's/lockright last night. We did a test run at 2:00 AM with the stock tires and a severely raked suspension. That thing has a ton of torque with 28" tires, runs through the gears pretty quick.
33x10.5 BFG's are stacked in the garage, waiting for the front lift.
Fun stuff,
Mike
Old 07-24-2009, 03:31 AM
i need new shocks any way so it would be pointless to try and shim them. thanks for your input.
Old 07-24-2009, 06:47 PM
Dipstik_90's Avatar
I'm just saying if your going to go throught the trouble of putting the BJ spacers in, cranking the t-bars, AND doing a diff drop aren't you pretty much at bracket lift height? I rode in a truck with cranked t-bars and the ride was scary even after the alignment.
Old 07-24-2009, 10:12 PM
my t bars were cranked from the PO. and yes ile get close to the bracket lift hite but i just don't have the money to by a 4 inch lift plus the tires to go with it. bj spacers are cheap and t bars cost nothing. my ride right now isent that bad, its a little bumpy on ruff roads
Old 07-24-2009, 10:19 PM
rdrttoy's Avatar
you can buy shocks that are for lift kits that would work just fine for what you need. this link will let you choose the amout of lift you have and the shocks that you can run with that set up. http://www.summitracing.com/search/Y...D/?Ns=Rank|Asc
Old 07-25-2009, 05:14 PM
Azca's Avatar
I bought some Skyjackers, they are about the most inexpensive. They will give you the product numbers you need at their site. I picked mine up off of ebay after that. Order them at no more than 2" of lift and you will be good.
Diff drop is a must but cheap. Make sure you also get a swaybar drop or your front driveshaft will hit the swaybar. You can make one or just order it. For the time it takes to cut stock and find materials you may as well just order the stuff.
Old 07-25-2009, 05:50 PM
Alex 400's Avatar
well, in your first post, you didn't say you were getting diff drops, so we don't know what you have done/plan on doing. But the ride will suck none the less as the suspension will basically not flex.
Old 07-27-2009, 11:50 AM
stock as possible's Avatar
Is it the bj spacers, the torsion bar crank, or the combination of the two that stress the CV's?
Old 07-27-2009, 12:39 PM
OutlawMike's Avatar
I did my BJ lift over the weekend. I just put up a post on the build.
The OME shocks for my 1st gen rig fit perfect with the BJ lift in it. At full droop they do not limit travel and do not bottom out under compression. I am running the stock bump stops. I did not need to do any shimming of the shocks
I have the OME N98's in the front. Bought them through 4Wheel Parts, they are special order.
Mike
Old 07-28-2009, 09:06 AM
its the combination of both
4x4YOTA
08-23-2016 09:08 AM
89YodaRunner
09-30-2015 02:18 PM
JookUpVandetti
09-30-2015 08:58 AM
4runnerFireman
09-29-2015 06:24 AM
crash813
09-27-2015 07:15 AM
Quick Reply: BJ spacers
