Best flowing head for a 22r-e
So I already have a TRD cam in my factory 22R-E motor and it works great, but I am seeking more power. I read posts by different people suggesting that Engnbldr, LCEngineering and D.O.A. make the best performance heads. Can anyone make a suggestion on which company to purchase from.
I was also considering the adjusting the air flow meter a few teeth. Would this make any difference in perfromance? I am utilizing the factory air cleaner, a TRD cam ( the small one) and have an exhaust system from a V6 4Runner (cat back).
Thanks in advance.
Thanks in advance.
In terms of performance, you're wanting to match head flow (in CFM) to the right camshaft. LC advertises stage 1 - stage 5 heads in various CFM. Tim @ DOA has a ton of experience porting 22R series heads - he matches them to cams and will provide flow results. Tim did my head.
Engnbldr's son does head porting. I've heard good things and I really like Engnbldr, but I've never purchased a ported head from him or his son.
Adjusting the AFM adjusts your mixture across the board. I wouldn't suggest adjusting it unless you've done enough mods to justify the mixture change. The difference will be very small in most cases. If you do it, make sure you mark the original position.
I bought and RV head and a 261 cam from Tim. I am very happy with it, and they are great to work with. It's probably overkill right now, but I am planning to put on a Weber 38, headers, and a multi-spark coil.
justdifferentials
Just Differentials
09-17-2015 06:14 PM
