Bad vibration from engine under 1500 RPM's
Old Dec 12, 2007 | 08:17 AM
mtrdrms's Avatar
have an ongoing problem with my 90 22re 4x4 extracab 5 sp. It runs and drives great but it really doesnt like being under 1500 rpms when Im driving. If I short shift and Im just lugging along in 3rd or 4th or 5th gear it vibrates the whole truck and feels like something bad is gonna happen. Ive checked just about everything so any advice would be great.
thanks
Andy
Old Dec 12, 2007 | 08:21 AM
4Crawler's Avatar
Might check the motor and tranny mounts (2 motor, one each side and 1 under the t-case) to see if they are in good shape.
Old Dec 12, 2007 | 08:23 AM
mtrdrms's Avatar
True, I never checked the mounts. Thanks
Old Dec 13, 2007 | 05:15 AM
ozzydg55's Avatar
any problems with motor mounts
Old Dec 13, 2007 | 09:10 AM
mtrdrms's Avatar
Not that I could tell. If really feels like the timing is off. You know how it would really lug and shake the truck under load. thats what it feels like. I did inspect the mounts yesterday and this morning I checked the timing and adjusted the valves which were a little tight. No difference. Its especially bad in 4wd. I am assuming just becuase of the extra load. Any other suggestions?
Thanks
Andy
Old Dec 13, 2007 | 09:26 AM
4Crawler's Avatar
Motor mounts are hard to inspect visually. The steel case covers the rubber part and they will look good even if torn apart. The way I check mine is to put a floor or bottle jack under the oil pan (use a block of wood to protect the pan) and start lifting. You'll see the engine and frame start to rise for a while as you take the weight of the motor off the frame and suspension. Then, if the mount is broken, you'll see the engine keep lifting and the frame stop and the broken motor mount will separate.
Old Dec 13, 2007 | 12:26 PM
mtrdrms's Avatar
Thanks 4crawler for the reply. Thats good advice. As soon as it stops snowing here ill have to try that.
Andy
Old Apr 4, 2008 | 01:01 PM
mtrdrms's Avatar
Just wanted to give an update and say that I totally rebuilt the top end of the motor and timing chain and the problem is exactly the same. Im off to thoroghly inspect the mounts.
Old Aug 29, 2012 | 06:59 PM
4runninmuds's Avatar
And oldy, I know, but any chance you figured this out??? Cheers!
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
razorman8669
Jul 12, 2015 12:13 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
