Bad torsion bars?
Old 04-11-2006, 01:08 PM
jake the ssnake's Avatar
Bad torsion bars?
The other day I tried to adjust my torsion bars hoping to even my front end out (it leans about 1 inch on the driver side and rubs severely at full lock).Both of the adjuster bolts seemed to be at the same height.When I went to tighten it the nut turned,no surprise there.My question is will new bolts fix this?Or do I need new torsion bars?I really don't want to spend too much money on new torsion bars because I plan on doing a sas in the future.I drove for a while with a broken shock on the drivers side so thats probably what caused it.Is there anything else I can do to get that side raised up an inch w/out buying new torsion bars?
Old 04-11-2006, 01:28 PM
celica's Avatar
if you didn't strip the bolt you can hold it still with a wrench on the top
Old 04-11-2006, 02:44 PM
AH64ID's Avatar
It is possible that there just isnt enough resistance on the spring to keep the nut spinning?? Soak it in blaster overnight, then put a wrench on it, and pray. I broke one on my 95 trying to get my 92's bars into it. The bolt/nut combo isnt expensive if it breaks.
Old 04-11-2006, 03:12 PM
I soaked it twice,but my crappy adjustable wrench didn't hold to well so I need to get a wrench to fit it.It is a 22mm isn't it? Everytime I work on this truck I have to buy a new metric tool.It seems everything is bigger than 19mm.
Old 04-11-2006, 03:14 PM
AH64ID's Avatar
I usually cheat and use the closed standard size....
Old 04-11-2006, 03:22 PM
91_4x4runner's Avatar
Ditto with 4x4nala... they typically fit pretty close to the same sizes... maybe with just a tiny bit of play in it... Havent stripped one yet...
Old 04-11-2006, 03:31 PM
Whats that make it about a 7/8? It seems like I've "misplaced" all my wrenches over 3/4 of an inch and I have 3 of every size below it.
Old 04-11-2006, 04:39 PM
jmach1's Avatar
I like the idea of buying new tools, I just tell my wife I have to go to Sears to pick up some yard "Fertilizer" yeah thats it.
JMach1
Old 04-12-2006, 06:41 AM
celica's Avatar
As stupid as this sounds - You have the front off the ground while doing this right?
Old 04-12-2006, 08:06 AM
Bobakazi's Avatar
Talking
I sometimes do that myself. Isn't it funny how many import owners, where basically everything is metric, do not own metric tools? I think it is a conspiracy of some sort, but I cant quite put my finger on it.
That being said, 2 wrenches/sockets should be your key.
Old 04-12-2006, 08:08 AM
AH64ID's Avatar
Just go own a chevy for a few repairs and you will own every thing standard/metric talk about not making sence....
AH64ID's Avatar
Good point, as simple as it sounds, I have known lots of people to adjust them with it on the ground...It can be done but isn't easy....
Old 04-12-2006, 11:26 AM
Yes after working on/owning a few ls1's I can attest to that. It just seems like I always need the 20mm on up for the toyota.And yes I did have the front off the ground.
Old 04-12-2006, 12:51 PM
celica's Avatar
common toyota sizes 10,12,14,17,19,21 mm rarely larger
4.34runner88
08-11-2018 10:44 AM
andrewtexas123
07-06-2016 01:49 AM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
Quick Reply: Bad torsion bars?
