bad mass air sensor?
Old 07-22-2011, 05:54 AM
scott90's Avatar
I start it up cold it idles fine then after a couple minutes it will idle down to where it barely runs then when I take off its really hestitant and misses and surges on light acceleration but when I floor board it its fine..also when I'm driving ill get to around 3 grand and it will surge and cut out as if I hit rev limiter. It has a new CTS and a fresh tune up..the truck is lacking alot of power as well..I cleaned the throttle body last week too.any ideas?
Old 07-22-2011, 07:40 AM
BigBluePile's Avatar
What motor...................?
Old 07-22-2011, 07:43 AM
scott90's Avatar
Oh sorry haha..its a 3.0 v6
Old 07-22-2011, 07:48 AM
You could measure the resistance values on the AFM(not MAF) and see if it's within limits.
Old 07-22-2011, 07:50 AM
scott90's Avatar
Ok ill search how to do that.and post my readings
Old 07-22-2011, 07:53 AM
Ooook. Do you have an FSM or and online manual? That way you can compare your own readings. They're also trouble shooting trees that can help too
Old 07-22-2011, 08:02 AM
scott90's Avatar
Nope I tried searching on here and am having a hard time finding out how to test the afm.
Old 07-22-2011, 08:03 AM
Even a Haynes manual....?
Old 07-22-2011, 08:05 AM
scott90's Avatar
I have one that my dad bought for his 93 2wd 4cyl but it should have a chart for my truck in it.
Old 07-22-2011, 08:08 AM
uh...maybe...as longs as it has the 3.0 V6 stuff
Old 07-22-2011, 08:10 AM
scott90's Avatar
Should it have how to test the afm in there as well?
Old 07-22-2011, 08:19 AM
irab88's Avatar
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
there.
Old 12-10-2011, 03:45 PM
Lifted94XLT's Avatar
Any update on this?!! Mine's having the same issue, but its a first time start up and it does this as soon as its started. Haven't driven it yet though.
Old 12-11-2011, 08:36 PM
sidebarr7's Avatar
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf try this
Old 12-14-2011, 08:30 AM
scott90's Avatar
Nope my truck still does it but randomly it idles better after the new AFM but still lacks power and cuts out at high rpm hhhhelp lol
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
tj884Rdlx
08-28-2015 12:04 PM
sojourner567
07-16-2015 08:52 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: bad mass air sensor?
