Back window VERY low power, no power inside
Old 04-18-2010, 03:01 PM
MrPeepers's Avatar
Ok so I have a strange issue. My wife said her 95 runner will sometimes die on her. I tried asking when it would happen but couldn't find a pattern. She said it just happens sometimes, it will just die, tehn it will usually start back up, but sometimes it might take a minute to crank. I've checked all visible connections and fuses. Nothing looks out of the ordinary. Just a minute ago, I go to roll the back window down, and it wouldn't go down, I could see it shift a little and could hear the relay. But it wouldn't move up or down. So I went in the car to use the switch. I turned the ignition on and went to use the switch adn nothing. I also noticed that the radio didn't come on, and none of the dash lights stuff came on like the fan and clock. Then a couple seconds later everything kicked on and the badck window works. I was suspecting the ignintion swithc but this kind of rules out the ignition switch. But I don't know what this sounds like. Some kind of loose main ground perhaps? Any help would be appreciated.
Thanks
Old 04-18-2010, 03:25 PM
yotaman85's Avatar
check the power wire from the battery to the fuse box. mine was thrashed and made a huge difference in the back window operation.
Old 04-18-2010, 03:38 PM
Matt16's Avatar
The back window motor circuit has some kind of breaker in it- that's to say, if you keep trying to raise or lower the window and its not moving, the breaker will heat up and flip and you'll have to wait a couple seconds before you get any power to the back window. The breaker might affect other circuits as well. You probably need a new back window motor, but that can be had for cheap from other Toyotas if you cross reference part numbers. I did a write up a couple weeks ago.
Back window relay fix: https://www.yotatech.com/forums/f116...runner-137193/
Back window motor replacement: https://www.yotatech.com/forums/f116...cement-209572/
Old 04-18-2010, 03:58 PM
yotaman85's Avatar
I also did a write up about the power supply wire, I will post a link. as should matt..
plus, the power wire mod was a whole $10 and 30min of time.
Old 04-18-2010, 03:59 PM
yotaman85's Avatar
here you go..
https://www.yotatech.com/forums/f116...er+supply+wire
Old 05-03-2010, 07:01 AM
MrPeepers's Avatar
Originally Posted by yotaman85
Wanted to post back and say Thank You very much! That was it. Previously, I was actually able to kill the engine by rolling all the windows up all the way and then holding all 4 window switches up with the headlights on. The headlights would dim like crazy and the motor would die. After doing this fix I can do this and the headlights barely dim at all. I also noticed a lot of corrosion on the little metal battery terminal clamp and noticed the post that the battery cables bolt onto is seperate so I took that all apart and cleaned the corrosion off.
Thanks again!
yourrealdad
7
07-21-2015 08:53 AM
scottt80
07-01-2015 12:13 PM
williemon
06-21-2002 01:32 PM
Quick Reply: Back window VERY low power, no power inside
