Back window question
Old Jan 25, 2007 | 12:17 PM
BlackSR5's Avatar
Has anyone ever seen a solid factory rear window without a slider on an extended cab 2nd gen pickup? I am trying to find a window to replace the rear slider on my 94. I dont ever use the slider anyway and I prefer the clear view I had on my previous truck. Thanks in advance.
Old Jan 25, 2007 | 12:21 PM
mastacox's Avatar
Make your own out of plexiglass.
Old Jan 25, 2007 | 12:52 PM
BlackSR5's Avatar
Nah I dont think that will keep out the cold well enough in the northeast I want a real window...Thanks for the idea though, maybe I can get somebody to make me a piece of glass to fit the frame.
Old Jan 25, 2007 | 01:04 PM
mastacox's Avatar
I beg to differ
It turns out that silicon glass's thermal conductivity is about 1.38 W/m*K, where as plexiglass's is a mere 0.21 W/m*K. That basically means that plexiglass is 7 times better at insulating than glass.
I can understand if you don't want to use plexiglass for other reasons, but thermal insulation ain't one of them
Old Jan 25, 2007 | 01:37 PM
BlackSR5's Avatar
Really....you learn something new every day. I would still feel better with glass though. All the plexi I have ever encountered scratches fairly easily, and I'm not sure how an electric defogger would work on it either...
Old Jan 25, 2007 | 01:40 PM
mastacox's Avatar
Hmm, you won't be able to get a defogger on a custom cut window either, but the "easily scratched" part is definitely a legitimate concern. If you get glass cut, make sure it's prestressed or has a poly layer on/in it, otherwise you might get a glass shard through the neck or something in a crash. Automotive glass is pre-stressed to make sure when/if it breaks, it shatters into tiny pieces, not big shards like plate glass.
Old Jan 25, 2007 | 01:54 PM
da_bigg_wigg's Avatar
I've seen it on 1st gen 4runners. It looked ghettorific though, and not in a crunk-adding way...
Still, if you can pull it off then all the power to ya
Old Jan 26, 2007 | 02:46 PM
rbh261's Avatar
I have a solid rear glass on mine. I removed the slider and ordered a new solid glass. The same gasket works on both.
Old Jan 17, 2008 | 01:38 AM
awareness's Avatar
I was curious about this myself, I was wondering if it was possible to get a solid rear window w/defrost replacement for my slider rear window. Not likely?
Old Jan 17, 2008 | 05:21 AM
MIKEMOKAS's Avatar
solid rear windows are out there.. try scavenging your local junkyards... dont think theres any with defoggers tho..
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
elwood73
Jul 5, 2015 07:07 AM
