Auto Trans advice needed please
Old 04-19-2011, 03:44 PM
markfagus's Avatar
Question Auto Trans advice needed please
Guys, I have a 88 3.0 auto. When I bought it a few months ago it had been sitting for 2+ years. I did the head gasket and a few other issues and now am tackling the tranny issue that has been there since I got the truck.
It shift fine in R and thru 1-2-3 but will not go into OD. I disconnected the computer under the console and test drove it shifting manually and OD did engage. So I assumed it was a solenoid issue. I replaced the solenoids (all of them) and I am still not getting OD.
I initially checked everything under the hood so I know it is not an issue there.
Could it be the ECT computer that is an issue? Do these things ever fail? Or is it time for a rebuild on the tranny?
Any advice you can give is greatly appreciated!
Mark
Old 04-19-2011, 05:00 PM
markfagus's Avatar
ADMIN, can you kick this fool out of here?
Old 04-19-2011, 05:05 PM
swampfox's Avatar
Check the temp sensor for the trans ecu to see if the wire is damaged or it has a bad sensor.I am not sure which one it is but it should be next to the engine temp sensor.
x2 on kicking the fool out.
Old 04-19-2011, 06:42 PM
jbtvt's Avatar
OD also won't work if your fluid level isn't right on, it's really sensitive and can be tricky the way their hot/cold ranges are laid out. Check the manual for the exact temp range and use a thermometer if possible to make sure you're in it. Hot range seems to be more accurate. Might also try flushing and replacing with Valvoline Maxlife, good stuff.
Old 04-19-2011, 07:13 PM
markfagus's Avatar
jbyvt, fluid level is spot on. i wish it was that easy.
I was able to get OD to work when I disconnected the box under the console.
Old 04-19-2011, 08:32 PM
ToyoTech559's Avatar
my problem was a sticking T-Stat. causing the engine to never reach operating temp. make sure your reaching operating temp
Old 04-19-2011, 08:37 PM
markfagus's Avatar
I don't think that is it, this issue of no OD was happening before and after I replaced water pump and t-stat. Engine operating temp seems not to be the issue.
Keep the ideas coming, I am all ears and my patience is wearing thin...
Old 04-20-2011, 09:21 AM
jbtvt's Avatar
If you're sure of all this probably time to tear into it. Maybe try the diagnostic but I can't vouch for it personally. Guessing you have the A340H like I'm pretty sure I do on my '88? All the info you'll need from basic to rebuild at
http://www.pirate4x4.com/forum/showthread.php?t=587521
Old 04-20-2011, 09:38 AM
McKenna's Avatar
Did you change out the Solenoid in the T-case as well ? I know you said all of them but some people only mean the ones attached to the trans.
Old 04-20-2011, 12:07 PM
markfagus's Avatar
McKenna, I did not change that one. I bought a kit and replaced all that were in the kit (the ones in the tranny)
Could the solenoid in the t-case cause the problem I have described?
Old 04-20-2011, 12:21 PM
McKenna's Avatar
I believe the Solenoid in the T-Case is your OD solenoid, from what I remember.
vasinvictor
01-20-2016 12:39 PM
BLRobertson
3.4 Swaps
07-10-2015 04:27 AM
BigArt70
06-30-2015 09:51 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Auto Trans advice needed please
